How to change this code to picbasic pro.Also i want to use xtal 4MHZ
Code:#include <16f84a.h> #fuses HS,NOWDT,PROTECT,PUT #use delay(clock=20000000) //one instruction=0.2us //////////////////////////// HS1YWN ///////////////////////////////// void main() { int ltime; SET_TRIS_B(0x00); for (ltime=0;ltime<50;ltime++) { output_high(PIN_B7); delay_ms(50); output_low(PIN_B7); delay_ms(50); } while (TRUE) { output_b(0x01); delay_cycles(59); output_b(0x02); delay_cycles(59); output_b(0x41); delay_cycles(59); output_b(0x42); delay_cycles(59); } } /////////////////////// the end !! ////////////////////////////////////////
