Number Sort Algorithm
Results 1 to 40 of 55
    May 2008
    Italy
    Default A workaround to avoid long
    Hi Bo,
    clear now. One workaround for not using long and still average them in the conventional way is the following:
    RawData[0] = 0
    for DatSort = 4 to 11                               ' pick out middle 8 readings
    RawData[0] = RawData[0]  + (RawData[DatSort] - RawData[3])    ' extract the total difference
    NEXT DatSort
    RawData[0] = RawData[0]  >>3               ' average the total difference
    DatAvg =  RawData[0]  + RawData[3]       ' add the average difference to the subtractor
    You addup in RawData[0] all the differences , then you average them and finally you add them to the RawData[3], the subtractor.
    Al.
    Al, I'm confused..... Where does RawData[3] come from and whats in it?
    May 2008
    Italy
    Dave, RawData array will contain the 16 readings you have taken from your system (ADC ; counter; etc.) . Once you apply Miss Melanie's sorting algorithm you will end up with your 16 values ordered in ascending order RawData[0] will contain the smallest reading while RawData[15] will contain the largest one.
    The suggested technique is to discard the first 4 readings and the last 4 readings and average the central 8 reading, in such a way you will not enter into your average calculation anomalous reading (spikes for instance).
    The Boroko issue was that since he is using the 16 bits counter, he was concerned in averaging the 8 raw data in the coventional way, due to the fact that a word will overflow over 65k and he didn't want to use long type variable.
    This method, I have proposed, simply extract the differences from the 8 central values, which can be handled with a single word variable. Once the differences are extracted and summed up into RawData[0] (which is available because its content has been discarded) then you calculate the average shifting the bits with this instruction RawData[0] = RawData[0]>>3
    Now if you add this average to the subtractor used (in our case RawData[3]) all you get is the data average.
    Naturally the code snippet should be called after a call to the sorting routine.
    Hoping to have clear the matter.
    Al.
    Feb 2008
    Michigan, USA
    Hi folks,
    Well, another learning moment! For the past week or so, I have been working on the previously mentioned sorting algorithm. I have been peeking in on the forum, but saw Al's name as the last one that replied so I didn't open it. Of course, I missed that there were actually 2 replies and that masked that there had been activity.
    Thanks for the suggestion. I will study it and see how long it takes me to understand it.
    In the mean time, this is where I have been churning. Puzzles me greatly, because it doesn't give anything near what I think it should.
    '*          :  18F1330                                          *
    DEFINE OSC 32
    OSCCON  = %11111100          ' INTOSC primary, 8MHz
    OSCTUNE = %11111111          ' ENABLE 4x PLL = 32mHz
    DEFINE HSER_RCSTA 90h        ' Enable serial port & continuous receive
    DEFINE HSER_TXSTA 24h        ' Enable transmit, BRGH = 1
    DEFINE HSER_CLROERR 1        ' Clear overflow automatically
    DEFINE HSER_SPBRG 138        ' 57600 Baud @ 32MHz, -0.08%
    SPBRGH = 0
    BAUDCON.3 = 1                ' Enable 16 bit baudrate generator
    DataA   var WORD
    RawData var WORD [16]           'full program uses 16 and strips top
    DatAvg  var byte                '   and bottom readings
    DatSort var byte                '
    DatCnt  var byte                ' count the 16 data entries
    AvgCount con 8                  ' number of readings to average (1/x)
    DatAvg   = 2500                 ' seed number to start averaging
    RawData[4]= 20000                ' this data represents 8 different
    RawData[5]= 21000                ' readings that come from a TMR0
    RawData[6]= 22000                ' capture that is working.  Fixed
    RawData[7]= 23000                ' values here for testing
    RawData[8]= 24000
    RawData[9]= 25000
    RawData[10]= 26000
    RawData[11]= 27000
    pause 2000
    '-- Average middle 8 readings ---------------------------------------
    Average:
       for DatSort = 0 to 7                    ' get 8 readings
        Hserout["DA=",#DatAvg,", RD",#DatSort,"=",#RawData[DatSort]]
        DatAvg = DatAvg - (DatAvg/AvgCount)             'subtract 1/x from Avg
        hserout[", 1/x=",#(DatAvg/AvgCount)," DA- = ",#DatAvg]
        DatAvg = DatAvg + (RawData[DatSort]/AvgCount)  'add 1/x of new reading
        Hserout[", DA+ = ",#DatAvg,13,10]
         next DatSort
      hserout[13,10]
    '    hserout[", DA ",#DatAvg,13,10]
       goto Average
    Here is a RealTerm screen of the output
    DA=219, RD4=20000, 1/x=24 DA- = 192, DA+ = 132
    DA=132, RD5=21000, 1/x=14 DA- = 116, DA+ = 181
    DA=181, RD6=22000, 1/x=19 DA- = 159, DA+ = 93
    DA=93, RD7=23000, 1/x=10 DA- = 82, DA+ = 141
    DA=141, RD8=24000, 1/x=15 DA- = 124, DA+ = 52
    DA=52, RD9=25000, 1/x=5 DA- = 46, DA+ = 99
    DA=99, RD10=26000, 1/x=10 DA- = 87, DA+ = 9
    DA=9, RD11=27000, 1/x=1 DA- = 8, DA+ = 55
    DA=55, RD4=20000, 1/x=6 DA- = 49, DA+ = 245
    DA=245, RD5=21000, 1/x=26 DA- = 215, DA+ = 24
    DA=24, RD6=22000, 1/x=2 DA- = 21, DA+ = 211
    DA=211, RD7=23000, 1/x=23 DA- = 185, DA+ = 244
    DA=244, RD8=24000, 1/x=26 DA- = 214, DA+ = 142
    DA=142, RD9=25000, 1/x=15 DA- = 125, DA+ = 178
    DA=178, RD10=26000, 1/x=19 DA- = 156, DA+ = 78
    DA=78, RD11=27000, 1/x=8 DA- = 69, DA+ = 116
    I can't yet find a pattern or a reason. Maybe its time for a bit of sleep. I will work on it more later.
    Bo
    Feb 2008
    Michigan, USA
    Default I'm impressed!
    Hi Al
    I had the same question as Dave until I mapped it out. Until I put it into Excel, I couldn't understand how that was going to work. Very cool indeed.
    The value in RawData[3] didn't matter, since the values were already sorted, it was lower than RD[4]. All it needed to do was act as a reference for the subtraction and then it was added back in canceling itself. I have no idea how you came up with that, but I'm glad folks like you are willing to teach the rest of us.
    The .xls is zipped if anyone would like to see it.
    Bo
    Feb 2008
    Michigan, USA
    Error found:
    The output from the code on post #52 didn't make sense because somewhere I had aliased a word variable to a byte. For some reason, they don't work the same....
    Things seem to be going much better now.
    Bo
  1. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 18:03
  2. Working with the random number generator
    By kwelna in forum mel PIC BASIC
    Last Post: - 16th January 2007, 18:50
  3. Random number results
    By bartman in forum mel PIC BASIC
    Last Post: - 9th March 2005, 18:39
  4. more random number questions
    Last Post: - 14th November 2004, 18:55
  5. Split number into variables
    By psmeets in forum mel PIC BASIC Pro
    Last Post: - 7th January 2004, 05:15
