Hi Al,
Thanks for engaging in this thread. Sometimes when one posts and gets no response, you begin to worry if your question is so off the wall that no one is interested.
The values that I'm working with are actually timer values that are WORD sized. The ultimate result is measuring ultrasonic pulse return to calculate distance. In the real program, I'm using a comparator interrupt to grab of the values. That one uses the analog, but here I'm just trying to sort out the averaging scheme.
The response needs to be smoothed considerably due to the high instance of random response of the ultrasonics. The values go on to determine the PWM output that drive a servo valve that controls some heavy hydraulics that can't tolerate quick movement. The response time needs to be in the 2-3 second range with smooth changes to work well. Since the values are 0-65535, and readings every 30mS, I'm trying to use Melanie's suggestions to dump the extremes, and DT's averaging to get away from LONGs and 32 bit math.
Current testing is with a second PIC generating the return pulse timing to separate the circuit from the program so that I can find the weakness. I'm trying to send a serial in to simulate the echo numbers. The next step is to convert the RX bytes into WORDS and see if the program works correctly.
Back to Burn and Turn
Bo
