Number Sort Algorithm
Results 1 to 40 of 55
    T.Jackson's Avatar
    T.Jackson Guest
    I normally have the ability to at least come up with some sort of opinion with most things (often it's wrong), but on that, I can't even think of one guess, not even an obviously far-fetched one.
    Going back to the early days of PBP, before Microcode studio, to the days when you carved your code into slate tablets, there was an anomaly/bug with PBP sometimes handling math within array parenthesis. The workaround was to simply add a dummy argument (which goes to show how old that code is). Now I can't remember at which point the error was eradicated without compiling a bunch of test samples across more than half-a-dozen versions of PBP. The code I posted above pretty much works with all versions, though if absolute speed is your thing, you can probably lose the +0 if your PBP is relatively up-to-date.
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Oh! - well that puts my mind at ease, it's things like that keep me from getting a good nights sleep. I'll be able to switch off tonight and get some rest.
  1. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  2. Working with the random number generator
    By kwelna in forum mel PIC BASIC
    Last Post: - 16th January 2007, 17:50
  3. Random number results
    By bartman in forum mel PIC BASIC
    Last Post: - 9th March 2005, 17:39
  4. more random number questions
    Last Post: - 14th November 2004, 17:55
  5. Split number into variables
    By psmeets in forum mel PIC BASIC Pro
    Last Post: - 7th January 2004, 04:15
