Uber noob needs clarity!
Results 1 to 7 of 7
    Apr 2007
    Default Uber noob needs clarity!
    Hello all,
    Just to keep things simple and not going into alot of details here is my question:
    Can you use a variable in the port settings?
    Example....
    for I = 0 to 7
    if portb.I = 1 then xxxxx
    next I
    If so how do you setup the variable? (I var byte)
    I have tired and tried and it always says:
    "ERROR Line X: Bad variable modifier: .I."
    What I am trying to do is scan a port for changes with out using 8 seperate If...then lines.
    Any help is always appreciated.
    Bill12780
    SETUP:
    16f873
    easypic4 dev board
    picbasic pro v2.47
    using PM as compiler
    Jul 2007
    Default May I suggest this
    UNTESTED, but with no compile error.
    You can try
    for I = 0 to 7
    if (portb & DCD I) = 1 then xxxxx
    next I
    J-P
    Apr 2006
    New Hampshire USA
    Smile See if this helps....
    Hi Bill12780,
    Take a look at this post and see if it helps.
    Bits, Bytes Words and Arrays - Melanie
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    -Adam-
    I think this is what you are looking for. In the manual under "Ports and other Registers".
    anyvar = PORTB & $0f   'Isolate lower 4 bits of PORTB and place result into anyvar
    $0f = 00001111
    $00ff = 11111111
    Now you can check "anyvar" for changes.
    Apr 2007
    Default Thanks a bunch man!
    Thanks everyone...
    These are some really good idea's. I had to "walk away" for awhile. I will read Melanie's post(man she is a wealth of knowledge....Bet she was born with a PBP manual in her hand!), try a few things. and get back with you all tonight.
    Thanks for the tips.
    Bill12780
    This will work;
    X VAR BYTE
      for X = 0 to 7
          if PortB.0[X] = 1 then xxxxx
      next X
    PortB.0 <-- zero after PortB indicates you're dealing with a bit.
    PortB.0[X] <-- [X] = the bit index pointer.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Apr 2007
    Default bruce is the man!
    "PortB.0 <-- zero after PortB indicates you're dealing with a bit.
    PortB.0[X] <-- [X] = the bit index pointer."
    Thanks bruce that is a brilliant little tidbit of information (for a noob like me)that I probly glazed over in the manual 20 times and it never stuck..
    Thanks! I knew it could be done like that...Just not smart enought to figure out how! hahha
    thanks again!
    Bill12780
  1. NOOB in need of help
    By studysession in forum mel PIC BASIC Pro
    Last Post: - 27th January 2009, 00:01
  2. Replies: 2
    Last Post: - 7th March 2008, 03:16
  3. Help a noob out?
    By yasiryassin in forum mel PIC BASIC
    Last Post: - 15th January 2008, 07:37
  4. Crystals & Caps - Super noob question??
    By kevj in forum General
    Last Post: - 24th September 2007, 18:11
