Need help with I2C syntax problem?
Results 1 to 6 of 6
    Hello Michael,
    It compiles ok for me for a 16f884, not so with say 16f877. Is there more code like say config fuse settings which could be throwing you a curve?
    I did not read any data sheets to see if 16f877 has I2C, maybe why it does not compile. also how old a version of PBP are you using?
    JS
    Which PIC are you using?
    Whiche IDE?
    Smile
    Thanks for the help guys... For some reason everything's working fine today. Haven't changed a thing...I was programming on a computer that had been brought out of hibernation. Thinking back, I've repeatedly had a few problems I couldn't explain. Perhaps there's a problem with the ram, or maybe it's just time to do a clean installation again...
  1. I2C Master/Slave 16F88/16F767 working code
  2. HARDWARE I2C SAMPLE CODE question
  3. Another I2C Slave Routine Problem
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 05:50
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
  5. I2C eeprom and DS1307 @40MHz problem
    By ius01 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2007, 07:41
