Tonights Question
Results 1 to 5 of 5
    Jul 2007
    Default Tonights Question
    Hi there all you electro guru's,
    Thanks to all who helped me with my last little endeavour. Tonights question is: why does this code bring up a line of black boxes across the bottom row of my LCD. It is a 2 line LCD. The initial flash routine of the indicator LED works fine as to the slow pulses during the loop. I assume I've left plenty of time for initialisation. I am using a 16F84a. Contrast works fine. I'm at a loss (again )....Any suggestions welcome
    Bombay, India
    You should write to the second line. I use code like this
            LCDOut $FE, $01, "    El-Guard    "
            LCDOut $FE, $C0, "Master  Keyboard"
            pause 1000                      ' wait for a second
    This code displays two lines on the display
    Hope this helps
    Jerson
    Jul 2007
    Unhappy No Joy
    Thanks for that Jerson, I replaced my output code with your patch and get the same result on my LCD (this is me scratching my head //) )
    I don't see any lcd defines
    ' LCD setup
    DEFINE LCD_DREG PORTB ' LCD data port
    DEFINE LCD_DBIT 0 ' LCD data starting bit
    DEFINE LCD_RSREG PORTA ' LCD register select port
    DEFINE LCD_RSBIT 1 ' LCD register select bit
    DEFINE LCD_EREG PORTA ' LCD enable port
    DEFINE LCD_EBIT 2 ' LCD enable bit
    DEFINE LCD_BITS 4 ' LCD data bus size
    DEFINE LCD_LINES 2 ' Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 ' Command delay time in us
    DEFINE LCD_DATAUS 50 ' Data delay time in us
    LCDOUT "HELLO WORLD"
    From the PBP manual.
    PBP assumes the LCD is connected to specific pins unless told
    otherwise using DEFINEs. It assumes the LCD will be used with a 4-bit
    bus with data lines DB4 - DB7 connected to PICmicro MCU PORTA.0 -
    PORTA.3, Register Select to PORTA.4 and Enable to PORTB.3.
    It is also preset to initialize the LCD to a 2 line display.
    To change this setup, place one or more of the following DEFINEs, all in
    upper-case, at the top of your PicBasic Pro program:
    It looks like you are using the sample program in PBP. Make sure you have it wired just like the manual said and Jerson's code should work.
    If you are still having trouble with line two and line one is working, try using the DEFINES. There is a DEFINE for line two. Just add the DEFINEs to match the way you have it wired.
  1. ADCIN question
    By Greg McFadden in forum General
    Last Post: - 16th September 2008, 03:53
  2. FREQOUT - PWM question
    By Etcho in forum mel PIC BASIC Pro
    Last Post: - 26th February 2007, 00:51
  3. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
  4. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
