Measure cable length with a PIC?
Results 1 to 5 of 5
    Perth, Australia
    Default Measure cable length with a PIC?
    I'm wanting to make a PIC program that can measure the length of a cable.
    The idea is to be able to connect both ends of the cable to different i/o pins and have the PIC calculate how long the cable is.
    I know this should be possible, as i've seen cable testers that can do it. Also, my PC's bios can tell me how long my network cable is, down to 0.1 of a meter.
    Obviously sending a pulse down the cable and timing how long it takes to reach the other end is out of the question as the PIC wouldn't be anywhere near fast enough.
    Does anybody know (or have any ideas) on how this can be done?
    Apr 2006
    New Hampshire USA
    Lightbulb Time-domain reflectometer (TDR)
    Hi Kamikaze47,
    Quote Originally Posted by Kamikaze47 View Post
    Look for:
    Time-domain reflectometry (TDR)
    Here is a very good DYI article using a 74AC04 hex inverter (not PIC) and your OldSillyScope.
    The author mentions the timing and velocity factors that might help with your project.
    QEX sample PDF article
    “Build a cheap and simple time-domain reflectometer”.
    Hook this up to your oscilloscope, and you can electronically measure the length of a wire to the end, or find a problem in the wire, including where the problem is physically located.
    http://www.arrl.org/qex/2006/03/steinbaugh.pdf
    -Adam-
    Perth, Australia
    Problem is, even with a PIC with a 40Mhz clock, the quickest interval you can measure is 100nS. In the cable i'm using, signals travel at 71% the speed of light. Which means 100nS equates to 56.8m. Obviously thats nowhere near the resolution required. To measure within 1m i'd need a clock speed of 2.2GHz - Obviously not going to happen on a pic.
    Im wondering how the hand-held cable testers manage that kind of timing.
    Not sure if this will work as the resistance will be low on a short cable, but this might be a place for RCTIME.
    Known capacitance find the resistance. Calculate for wire diameter.
    Italy
    Virtual Cable Tester™ (VCT)
    Technology For Gigabit Networks
    White paper:
    http://www.marvell.com/products/tran...hite_Paper.pdf
    Video about VCT advantages. (46MB zip file/ non-technical).
    http://www.marvell.com/products/VCT%20Video.zip
    Best regards,
    Luciano
  1. DLR3 Data cable to pic
    By ZOOM in forum GSM
    Last Post: - 14th May 2010, 15:50
  2. DS1820 Max Cable length ?
    By dccch in forum General
    Last Post: - 24th January 2008, 07:44
  3. Maximun Cable Length for PIC to LCD
    By wildbilly in forum mel PIC BASIC Pro
    Last Post: - 1st January 2008, 19:00
  4. PIC to PIC Serial data using Cat5 cable
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2007, 02:42
