I start over from the begining and now it's working.
Thanks for all help!
/Håkan
'   Pic Definition
        ' Using PIC 16F874 @ 4MHZ and bootloader
        DEFINE LOADER_USED 1
        DEFINE LCD_DREG PORTB   ' Set LCD Data port
        DEFINE LCD_DBIT 0       ' Set starting Data bit (0 or 4) if 4-bit bus
        DEFINE LCD_RSREG PORTB  ' Set LCD Register Select port
        DEFINE LCD_RSBIT 7      ' Set LCD Register Select bit
        DEFINE LCD_RWREG PORTB  'LCD read/write port
        DEFINE LCD_RWBIT 6      'LCD read/write bit
        DEFINE LCD_EREG PORTB   ' Set LCD Enable port
        DEFINE LCD_EBIT 5       ' Set LCD Enable bit
        DEFINE LCD_BITS 4       ' Set LCD bus size (4 or 8 bits)
        DEFINE LCD_LINES 2      ' Set number of lines on LCD
        DEFINE LCD_COMMANDUS 2000' Set command delay time in us
        DEFINE LCD_DATAUS 50    ' Set data delay time in us
    '   Hardware configuration
        TRISC  = %10000000    ' PORTC.7 is the RX input
                              ' PORTC.6 is the TX output
        On Interrupt Goto myint ' Define interrupt handler
        INTCON      =   %11000000            ' Enable INTE interrupt
        PIE1.5      =   1
        T2CON       =   %01111111
        PIE1.1      =   1
        ' LCD background
        LED             var     PORTD.3
        ' LCD
        LcdCls          CON     $01     ' clear the LCD
        LcdLine1        CON     $80     ' DDRAM address of line 1
        LcdLine2        CON     $C0     ' DDRAM address of line 2
        ' Shaft Encoder
        clock           var     PORTD.0
        stat            var     PORTD.1
        ' ExecuteButton
        exec            var     PORTD.2
    '   Serial communication definition
        ' Using internal USART and MAX232 to interface to PC
        'RCSTA = $90
        DEFINE HSER_RCSTA 90h ' enable serial port, enable continuous receive
        'TXSTA = $20
        define HSER_TXSTA 20h ' enable transmit, BRGH=1
        'SPBRG = 25
        define HSER_SPBRG 25 ' set baudrate to 2400
        DEFINE HSER_CLOERR  1 ' automatic clear overrun error
        T2400           CON     396
        Inverted        CON     $4000
        Baud            CON     T2400 '+ Inverted
        txPin           var     PORTC.6
        rxPin           Var     PORTC.7
    '   Alias definition
        RCIF VAR PIR1.5     ' Receive  interrupt flag (1=full , 0=empty)
        TXIF VAR PIR1.4     ' Transmit interrupt flag (1=empty, 0=full)
        OERR var RCSTA.1    ' Overrun error
        CREN var RCSTA.4    ' Continuous receive
        dump            var     byte
        countPulses     VAR     Byte
        print           VAR     Bit
        a               VAR     Byte
        b               VAR     Byte
        c               var     byte
        idx             var     byte
        turnOff         VAR     Bit
        failSafe        VAR     Byte
        timer           var     word
    '   Hardware initialisation
        pause 10 ' safe start-up delay
        countpulses = 1
        turnOff = 0
        print = 0
        high    led
        GOSUB   readpuls
        GOSUB   writeDisp
        GOSUB   readExec
        pause 10
    writeDisp:
            IF (print) THEN
              SELECT case countPulses
              CASE 1
                 lcdout $FE,  LcdCls, "Start ALL Syst. "
              CASE 2
                 lcdout $FE,  LcdCls, "Main Sound Syst."
              CASE 3
                 lcdout $FE,  LcdCls, "Sub Sound Syst. "
              CASE 4
                 lcdout $FE,  LcdCls, "Main Disp System"
              CASE 5
                 lcdout $FE,  LcdCls, "Sub Disp System "
              CASE ELSE
                 lcdout $FE,  LcdCls, " Illigal value  "
              END SELECT
              Print = 0
    readExec:
            IF (exec = 0) THEN
                  lcdout $FE,  LcdLine2, "  Starting Up   "
                    gosub set
                  GOSUB logOff
                  lcdout $FE,  LcdLine2, "  Shuting Down  "
                    gosub clr
                  lcdout $FE,  LcdLine2, "                "
    readPuls:
            IF(clock = 0) THEN
              IF (stat) THEN
                countpulses = ((countpulses - 1)//5)+1'(countpulses - 1) MIN 1'((countpulses - 1)//5)
                countpulses = ((countpulses + 1)//5)+1'(countpulses + 1) MAX 5'((countpulses + 1)//5)
              print = 1
              high led
              PIE1.0 = 1
              again:  IF clock = 0 THEN GOTO again
              high led
    set:
                read countpulses*2, a
                read countpulses*2+1, b
                for idx = a to b
                  read idx,c
                  'SEROUT2 txPin, baud,[13,(c dig 1),"S",(c dig 0)+48,((13 + (c dig 1) + "S" + 48+(c dig 0))^$FF)+1]
                  hserout [13,(c dig 1),"S",(c dig 0)+48,((13 + (c dig 1) + "S" + 48+(c dig 0))^$FF)+1]
                next
    clr:
                for idx = b to a step -1
                  read idx,c
                  if ((c dig 2)= 1) then
                    pause 5000
                  'SEROUT2 txPin, baud,[13,(c dig 1),"C",(c dig 0) + 48,((13 + (c dig 1) + "C" + 48 +(c dig 0))^$FF)+1]
                  hserout [13,(c dig 1),"C",(c dig 0) + 48,((13 + (c dig 1) + "C" + 48 +(c dig 0))^$FF)+1]
                next
    logOff:
            lcdout $FE,  LcdLine2, " All systems GO "
            failsafe = 0
            turnOff = 0
    logOffloop:
            IF (exec = 0) THEN
               PAUSE 10
       loop1:  IF (exec = 0) THEN loop1
               IF turnOff THEN
                 lcdout $FE,  LcdLine2, "OK, to turn OFF?"
                 PAUSE 200
                 failsafe = 0
                 turnOff = 1
               failSafe = failSafe + 1
               IF failSafe > 10 THEN
                 turnOff = 0
                 PAUSE 10
                 failsafe = 0
            PAUSE 100
            GOTO logOffLoop
    ' Interrupt handler
        Disable                 ' No interrupts past this point
myint:  if RCIF = 1 then
            hserin[WAIT($01),a]
            b = 0
            while a = $02
                hserin[a]
                write b, a
                b = b + 1
            wend
            While RCif         ' Code until I write the right rutine
                Dump=RCREG
            WEND
            lcdout $FE, LcdLine2, " Connected "
            timer = timer+1
            if timer > $FFFE then
                low led
                PIE1.1 = 0
        Resume                  ' Return to main program
        Enable
