Rc int on 16f874
Results 1 to 6 of 6
    Jul 2006
    Default Rc int on 16f874
    Hello!
    I'm trying to connect to my PIC via a interupt on receivd rs232. The hardware is connected as attachment "Hardware Setup.jpg" (MicroCodeLoader).
    My problem is when I try to connect nothing happends.
    Here is my code:
    <PBP COD>
    DEFINE LOADER_USED 1
    ' Set X-tal to 4 MHz
    DEFINE HSER_RCSTA 90h 'Hser receive status init
    DEFINE HSER_TXSTA 20h 'Hser transmit status init
    DEFINE HSER_BAUD 2400 'Hser baud rate
    SPBRG = 25'103 'SET TO 2400bps
    On Interrupt Goto myint ' Define interrupt handler
    INTCON = $C0 ' Enable INTE interrupt
    PIE1.5 = 1
    ' Interrupt handler
    Disable ' No interrupts past this point
    myint:
    PIR1.5 = 0
    lcdout $FE, LcdLine2, " Connected "
    Resume ' Return to main program
    Enable
    </PBP COD>
    Whats wrong? I can't get it to work!
    Pleas help me.
    Håkan
    ( I hope you can understand my por english and code)
    we will need to see your whole code first... sure there's few things missing here..
    Jul 2006
    OK, here is my entire code.
    I have a 2*16 LCD, a button and a shaft encoder connected.
    Håkan
    ' Set LCD Data port
    DEFINE LCD_DREG PORTB
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 0
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTB
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 7
    'LCD read/write port
    DEFINE LCD_RWREG PORTB
    'LCD read/write bit
    DEFINE LCD_RWBIT 6
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTB
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 5
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 2000
    ' Set data delay time in us
    DEFINE LCD_DATAUS 50
    INTCON.6 = 1' = $C0 ' Enable INTE interrupt
    PIE1.5 = 1
    ' Shaft Encoder
    clock var PORTD.0
    stat var PORTD.1
    ' Button
    exec var PORTD.2
    ' ICD
    txPin var PORTC.6
    rxPin Var PORTC.7
    ' LCD background
    LED var PORTD.3
    T2400 CON 396'1021
    Inverted CON $4000
    Baud CON T2400 '+ Inverted
    LcdCls CON $01 ' clear the LCD
    LcdLine1 CON $80 ' DDRAM address of line 1
    LcdLine2 CON $C0 ' DDRAM address of line 2
    countPulses VAR Byte
    print VAR Bit
    a VAR Byte
    b VAR Byte
    c var byte
    idx var byte
    turnOff VAR Bit
    failSafe VAR Byte
    'Init EE
    read $00,a
    if a <> 0 then
    ' First digit --> Delay when turnig off
    ' Second digit --> Card
    ' Therd digit --> Relay
    ' ALL system
    write 2,$A ' --> Start adr
    write 3,$D ' --> Stop adr
    write $A, 11
    write $B, 12
    write $C, 114
    write $D, 16
    ' Main Sound --> Mixerboard, eq, Ampl.
    ' Sub Sound --> Only Mixer and Eq etc.
    ' Main Displ --> Display Comp., screens and Projector
    ' Sub Displ --> Only Display Comp. and Screens
    write $00, $1
    PAUSE 1000 ' Wait for LCD to startup
    countpulses = 1
    turnOff = 0
    print = 0
    high led
    GOSUB readpuls
    GOSUB writeDisp
    GOSUB readExec
    GOTO main
    writeDisp:
    IF (print) THEN
    SELECT case countPulses
    CASE 1
    lcdout $FE, LcdCls, "Start ALL Syst. "
    CASE 2
    lcdout $FE, LcdCls, "Main Sound Syst."
    CASE 3
    lcdout $FE, LcdCls, "Sub Sound Syst. "
    CASE 4
    lcdout $FE, LcdCls, "Main Disp System"
    CASE 5
    lcdout $FE, LcdCls, "Sub Disp System "
    CASE ELSE
    lcdout $FE, LcdCls, " Illigal value "
    END SELECT
    Print = 0
    readExec:
    IF (exec = 0) THEN
    lcdout $FE, LcdLine2, " Starting Up "
    gosub set
    GOSUB logOff
    lcdout $FE, LcdLine2, " Shuting Down "
    gosub clr
    lcdout $FE, LcdLine2, " "
    readPuls:
    IF(clock = 0) THEN
    IF (stat) THEN
    countpulses = ((countpulses - 1)//5)+1'(countpulses - 1) MIN 1'((countpulses - 1)//5)
    countpulses = ((countpulses + 1)//5)+1'(countpulses + 1) MAX 5'((countpulses + 1)//5)
    print = 1
    again: IF clock = 0 THEN GOTO again
    high led
    set:
    read countpulses*2, a
    read countpulses*2+1, b
    for idx = a to b
    read idx,c
    SEROUT2 txPin, baud,[13,(c dig 1),"S",(c dig 0)+48,((13 + (c dig 1) + "S" + 48+(c dig 0))^$FF)+1]
    next
    clr:
    for idx = b to a step -1
    read idx,c
    if ((c dig 2)= 1) then
    pause 5000
    SEROUT2 txPin, baud,[13,(c dig 1),"C",(c dig 0) + 48,((13 + (c dig 1) + "C" + 48 +(c dig 0))^$FF)+1]
    next
    logOff:
    lcdout $FE, LcdLine2, " All systems GO "
    failsafe = 0
    turnOff = 0
    logOffloop:
    IF (exec = 0) THEN
    PAUSE 10
    loop1: IF (exec = 0) THEN loop1
    IF turnOff THEN
    lcdout $FE, LcdLine2, "OK, to turn OFF?"
    PAUSE 200
    failsafe = 0
    turnOff = 1
    failSafe = failSafe + 1
    IF failSafe > 10 THEN
    turnOff = 0
    PAUSE 10
    failsafe = 0
    PAUSE 100
    GOTO logOffLoop
    ' Interrupt handler
    myint:
    PIR1.5 = 0
    Enable
    PIR1,5 is a read only register, so you can't aletr it. To clear the RCIF flag, you need to read RCREG untill it's empty.
    ' Interrupt handler
    myint:
    While RCREG
        Dump=RCREG
        WEND
    Enable
    and then, as you don't use any HSERIN/HSEROUT, you need to change
    to
    RCSTA = $90 ' Enable serial port & continuous receive
    TXSTA = $20 ' Enable transmit, BRGH = 0
    SPBRG = 25  ' 2400 Baud @ 4MHz, 0.17%
    and...
    to
    INTCON=%11000000
    maybe i forgot few things... try it
    Jul 2006
    Thanks for your respond Mister_e.
    I have change the code, but no sucess.
    Are I'm thinking wrong. Shoudn't I jump into the interrupt rutine when I send a few letters with "Serial Communicator" (MicroCodeStudio +) to the PIC.
    Nothing hapends when I try.
    Jul 2006
    I start over from the begining and now it's working.
    Thanks for all help!
    /Håkan
    '   Pic Definition
            ' Using PIC 16F874 @ 4MHZ and bootloader
            DEFINE LCD_DREG PORTB   ' Set LCD Data port
            DEFINE LCD_DBIT 0       ' Set starting Data bit (0 or 4) if 4-bit bus
            DEFINE LCD_RSREG PORTB  ' Set LCD Register Select port
            DEFINE LCD_RSBIT 7      ' Set LCD Register Select bit
            DEFINE LCD_RWREG PORTB  'LCD read/write port
            DEFINE LCD_RWBIT 6      'LCD read/write bit
            DEFINE LCD_EREG PORTB   ' Set LCD Enable port
            DEFINE LCD_EBIT 5       ' Set LCD Enable bit
            DEFINE LCD_BITS 4       ' Set LCD bus size (4 or 8 bits)
            DEFINE LCD_LINES 2      ' Set number of lines on LCD
            DEFINE LCD_COMMANDUS 2000' Set command delay time in us
            DEFINE LCD_DATAUS 50    ' Set data delay time in us
        '   Hardware configuration
            TRISC  = %10000000    ' PORTC.7 is the RX input
                                  ' PORTC.6 is the TX output
            INTCON      =   %11000000            ' Enable INTE interrupt
            PIE1.5      =   1
            T2CON       =   %01111111
            PIE1.1      =   1
            ' LCD background
            LED             var     PORTD.3
            ' LCD
            ' Shaft Encoder
            clock           var     PORTD.0
            stat            var     PORTD.1
            ' ExecuteButton
            exec            var     PORTD.2
        '   Serial communication definition
            ' Using internal USART and MAX232 to interface to PC
            'RCSTA = $90
            DEFINE HSER_RCSTA 90h ' enable serial port, enable continuous receive
            'TXSTA = $20
            define HSER_TXSTA 20h ' enable transmit, BRGH=1
            'SPBRG = 25
            define HSER_SPBRG 25 ' set baudrate to 2400
            DEFINE HSER_CLOERR  1 ' automatic clear overrun error
            T2400           CON     396
            Inverted        CON     $4000
            txPin           var     PORTC.6
            rxPin           Var     PORTC.7
        '   Alias definition
            RCIF VAR PIR1.5     ' Receive  interrupt flag (1=full , 0=empty)
            TXIF VAR PIR1.4     ' Transmit interrupt flag (1=empty, 0=full)
            OERR var RCSTA.1    ' Overrun error
            CREN var RCSTA.4    ' Continuous receive
            dump            var     byte
            print           VAR     Bit
            a               VAR     Byte
            b               VAR     Byte
            c               var     byte
            idx             var     byte
            turnOff         VAR     Bit
            failSafe        VAR     Byte
            timer           var     word
        '   Hardware initialisation
            pause 10 ' safe start-up delay
            countpulses = 1
            turnOff = 0
            print = 0
            high    led
            GOSUB   readpuls
            GOSUB   writeDisp
            GOSUB   readExec
            pause 10
        writeDisp:
                IF (print) THEN
                  CASE 1
                  CASE 2
                  CASE 3
                  CASE 4
                  CASE 5
                  CASE ELSE
                  END SELECT
                  Print = 0
        readExec:
                IF (exec = 0) THEN
                        gosub set
                      GOSUB logOff
                        gosub clr
        readPuls:
                IF(clock = 0) THEN
                  IF (stat) THEN
                  print = 1
                  high led
                  PIE1.0 = 1
                  high led
        set:
                    for idx = a to b
                      read idx,c
                      'SEROUT2 txPin, baud,[13,(c dig 1),"S",(c dig 0)+48,((13 + (c dig 1) + "S" + 48+(c dig 0))^$FF)+1]
                      hserout [13,(c dig 1),"S",(c dig 0)+48,((13 + (c dig 1) + "S" + 48+(c dig 0))^$FF)+1]
                    next
        clr:
                      read idx,c
                        pause 5000
                      'SEROUT2 txPin, baud,[13,(c dig 1),"C",(c dig 0) + 48,((13 + (c dig 1) + "C" + 48 +(c dig 0))^$FF)+1]
                      hserout [13,(c dig 1),"C",(c dig 0) + 48,((13 + (c dig 1) + "C" + 48 +(c dig 0))^$FF)+1]
                    next
        logOff:
                failsafe = 0
                turnOff = 0
        logOffloop:
                IF (exec = 0) THEN
                   PAUSE 10
                   IF turnOff THEN
                     PAUSE 200
                     failsafe = 0
                     turnOff = 1
                     turnOff = 0
                     PAUSE 10
                     failsafe = 0
                PAUSE 100
                GOTO logOffLoop
        ' Interrupt handler
    myint:  if RCIF = 1 then
                hserin[WAIT($01),a]
                b = 0
                while a = $02
                    hserin[a]
                    write b, a
                    b = b + 1
                wend
                While RCif         ' Code until I write the right rutine
                    Dump=RCREG
                WEND
                timer = timer+1
                if timer > $FFFE then
                    low led
                    PIE1.1 = 0
            Enable
  1. RC Servo decoding/encoding using 12F683
    By ScaleRobotics in forum Code Examples
    Last Post: - 14th September 2010, 01:49
  2. Instant Int and encoder (Elect. Gearing)
    Last Post: - 29th November 2009, 03:29
  3. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
  4. strange int behaviour
    By tom in forum mel PIC BASIC Pro
    Last Post: - 17th November 2005, 16:41
  5. RC measuring routine Radio PCM
    By jetpr in forum mel PIC BASIC Pro
    Last Post: - 11th August 2005, 03:18
