Help with code, button
Results 1 to 12 of 12
    Yes, that is correct.
    Jul 2007
    I added it and it worked!
    Thanks.
    Jul 2007
    If I make the code like tis:
    @   device  pic16F648A, hs_osc, wdt_off, mclr_on, lvp_off, protect_off
    DEFINE OSC 20
    LED1 var PORTB.1
    PRESS var PORTA.1
    CMCON=7
    loop:
    If press=0 then
                high led1
                low led1
                goto loop
    Should it be like this?
    Quote Originally Posted by xobx View Post
    DEFINE OSC 20
    LED1 var PORTB.1
    PRESS var PORTA.1
    CMCON=7
    loop:
    If press=0 then
                high led1
                low led1
                goto loop
    No. The first way is what you want. When the switch is open the pin is "0"LOW. When the switch is closed the pin is "1"HIGH.
    If you are using push buttons, you will need to use either a normally open "NO" or a normally closed "NC".
    The resistor keeps the pin LOW (no float). High resistance is used to minimize the current through the switch (just a little short).
    Depending on how you look at it this is called a pull up or a pull down.
  1. TSA5512/5511 code for PIC16F877/84
    By Marin in forum mel PIC BASIC Pro
    Last Post: - 24th August 2013, 06:16
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
