Help with code, button
Results 1 to 12 of 12
    According to the data sheet it has two comparators.
    The above links will explain why
    CMCON=7
    is needed.
    Jul 2007
    Ok, thanks.
    But it still dosent work as I want it :/
    @   device  pic16F648A, hs_osc, wdt_off, mclr_on, lvp_off, protect_off
    DEFINE OSC 20
    LED1 var PORTB.1
    PRESS var PORTA.1
    CMCON=7
    loop:
    If press=1 then
                high led1
                low led1
                goto loop
    When i transfer it LED1 starts to shine directly even if PortA.1 doesnt have +5V
    Maybe the LED is backwards
    Do you have PORTA.1 tied to ground with a resistor (10K) so it is not floating?
    Jul 2007
    Floating ?
    Jul 2007
    Should it be like this?
    Yes, that is correct.
    Jul 2007
    I added it and it worked!
    Thanks.
  1. TSA5512/5511 code for PIC16F877/84
    By Marin in forum mel PIC BASIC Pro
    Last Post: - 24th August 2013, 06:16
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
