No. The first way is what you want. When the switch is open the pin is "0"LOW. When the switch is closed the pin is "1"HIGH.
If you are using push buttons, you will need to use either a normally open "NO" or a normally closed "NC".
The resistor keeps the pin LOW (no float). High resistance is used to minimize the current through the switch (just a little short).
Depending on how you look at it this is called a pull up or a pull down.
