I'm confused
Results 1 to 8 of 8
Thread: I'm confused
    Jul 2007
    Default Rehashed port settings
    Yeah sorry about that....originally the port settings were as schematic: l9=a0, l10=a1, l11=a2, l12=a3. I changed them later to check that it wasn't just something with a0 but as a few of you pointed out I can't use a4 for I/O so I shifted 'em back. Maybe the code I sent was the middle test 'era' as it stands the last 4 port settings are a0-->a3 respectively. I've tested this setup on 3 PICs and 3 bargraphs (2 green and 1 red) with the same result. So I tried a6....same result. Out of pure frustration I wired the a0 output to a totally independant standalone LED...which flashes perfectly at the right time. This would make me think that the problem is with the Bargraph. But if I just pulse l9 then it is fine and if you look at the original code there are two subroutines (standard and pulse) which work absolutely fine. I cannot for the life of me see any reason whatsoever why one LED would work perfectly with a signal whereas another would flash ever so briefly with the same signal yet work fine when another signal comes from the same line....totally inexplicable and maximum admiration to anyone who can work this out!!!
    Ok, Looking at the data sheet in section 11 VOLTAGE REFERENCE MODULE on page 68.
    11.5 Connection Considerations
    The Voltage Reference module operates independently
    of the Comparator module. The output of the reference
    generator may be connected to the RA2 pin if the
    TRISA<2> bit is set and the VROE bit, VRCON<6>, is
    set. Enabling the Voltage Reference module output onto
    the RA2 pin with an input signal present will increase
    current consumption. Connecting RA2 as a digital output
    with VREF enabled will also increase current consumption.
    The RA2 pin can be used as a simple D/A output with
    limited drive capability. Due to the limited drive
    capability, a buffer must be used in conjunction with the
    Voltage Reference module output for external connections
    to VREF. Figure 11-2 shows an example buffering
    I am sure Mister-E can clear this up if it is the problem, now I am in new ground
    Jul 2007
    Smile Thanks Dave
    Thanks Dave, (and mister_e and all who've contributed),
    I have to go to bed now as it's 3am and my boy's B'day tomorrow (today)....looks like I won't get the full coding down for his 'wrist scanner'...I'll work it out later and 'upgrade' him. Thanks again for all your help and if anyone actually puzzles this out I'll be all ears as to what's happening.
    Good night all
    The voltage reference is disabled by default, but yeah, not bad to make sure of everything
    CVRCON = 0 if my memory serves me well
    with CMCON = 7 it usually enough.
    Anyways, on this one, IF we want to have always the same brightness on ALL LED, we will need to do some TRIS and PORT tricks. Obviously our friend omit to add the resistor in his schematic, but no problem, i'm working on something right now.
    For once, i'll try it on a SIM
    Schematic is attached
    OK, here's the overcomplicated solution first...
        @ __CONFIG  _INTRC_OSC_NOCLKOUT & _MCLRE_ON  &  _LVP_OFF & _WDT_OFF & _PWRTE_ON  & _BODEN_ON
        PORTA = 0
        PORTB = 0
        TRISA = 0
        TRISB = 0
        CMCON = 7
        CounterA    var byte
        GOTO START
    @   IFNDEF KAPOUET
            PAUSE 0     ' include PAUSE?C macro
    @   ENDIF
    ON=1
    OFF=0
    BLINK=2
    CLEARALL    MACRO
       VARIABLE CLEARCOUNTER
    CLEARCOUNTER=1
        WHILE (CLEARCOUNTER<13)
            LED#v(CLEARCOUNTER) OFF
    CLEARCOUNTER++=1
        ENDW
        ENDM
    LED     MACRO  LEDOUT,ACTION,DELAY
        IF (ACTION == BLINK)
            LED#V(LEDOUT) ON
            PAUSE?C DELAY
            LED#V(LEDOUT) OFF
                LED#V(LEDOUT) ACTION
                PAUSE?C DELAY
        ENDM
    LED1    MACRO ACTION
        MOVE?CT 0,TRISB,0
        MOVE?CT ACTION,PORTB,0
        ENDM
    LED2    MACRO ACTION
        MOVE?CT 0, TRISB,1
        MOVE?CT 0, TRISB,2
        MOVE?CT ACTION,PORTB,1
        MOVE?CT 0,PORTB,2
        ENDM
    LED3    MACRO   ACTION
        MOVE?CT 1, TRISB,1
        MOVE?CT 0, TRISB,2
        MOVE?CT ACTION, PORTB,2
        ENDM
    LED4    MACRO ACTION
        MOVE?CT 0,TRISB,3
        MOVE?CT ACTION,PORTB,3
        ENDM
    LED5    MACRO ACTION
        MOVE?CT 0, TRISB,4
        MOVE?CT 0, TRISB,5
        MOVE?CT ACTION,PORTB,4
        MOVE?CT 0,PORTB,5
        ENDM
    LED6    MACRO   ACTION
        MOVE?CT 1, TRISB,4
        MOVE?CT 0, TRISB,5
        MOVE?CT ACTION, PORTB,5
        ENDM
    LED7    MACRO ACTION
        MOVE?CT 0, TRISB,6
        MOVE?CT 0, TRISB,7
        MOVE?CT ACTION,PORTB,6
        MOVE?CT 0,PORTB,7
        ENDM
    LED8    MACRO   ACTION
        MOVE?CT 1, TRISB,6
        MOVE?CT 0, TRISB,7
        MOVE?CT ACTION, PORTB,7
        ENDM
    LED9    MACRO ACTION
        MOVE?CT 0,TRISA,0
        MOVE?CT ACTION,PORTA,0
        ENDM
    LED10    MACRO ACTION
        MOVE?CT 0, TRISA,1
        MOVE?CT 0, TRISA,2
        MOVE?CT ACTION,PORTA,1
        MOVE?CT 0,PORTA,2
        ENDM
    LED11    MACRO   ACTION
        MOVE?CT 1, TRISA,1
        MOVE?CT 0, TRISA,2
        MOVE?CT ACTION, PORTA,2
        ENDM
    LED12    MACRO ACTION
        MOVE?CT 0,TRISA,3
        MOVE?CT ACTION,PORTA,3
        ENDM
    START:
        for countera =1 to 10
                LED 1,ON,0
                LED 4,ON,0
                LED 7,ON,0
                LED 10,ON,250
                CLEARALL
                LED 2,ON,0
                LED 5,ON,0
                LED 8,ON,0
                LED 11,ON,250
                CLEARALL
                LED 3,ON,0
                LED 6,ON,0
                LED 9,ON,0
                LED 12,ON,250
                CLEARALL
            next
        FOR COUNTERA= 1 TO 10
        asm
        variable CLED
    CLED=1
        while (CLED<13)
           LED CLED,BLINK,250
    CLED++=1
        ENDW
    CLED=11
        while (CLED>1)
           LED CLED,BLINK,250
    CLED--=1
        ENDW
        NEXT
        GOTO START
    now, i'll try to do something more 'user friendly
    Jul 2007
    Smile Thanks mister_e
    Thanks for all your help there and with my other posting re no attachments.
  1. confused
    By fowardbias in forum Serial
    Last Post: - 24th February 2010, 03:51
  2. Confused over A/D settings
    Last Post: - 22nd February 2010, 10:44
  3. 12C671 & Osccal register - I am confused
    Last Post: - 26th December 2009, 06:03
  4. 1.5 v to 3v and 5v? Really confused.
    By kevj in forum Schematics
    Last Post: - 17th October 2007, 14:16
  5. Hlp - newcomer getting confused
    By chunk in forum General
    Last Post: - 23rd January 2006, 18:47
