Port 'a' problems
Results 1 to 15 of 15
    Jul 2007
    Question Port 'a' problems
    I am writing a very simple (theoretically) string of code to flash some LED's in a variety of patterns on a 12 segment bar graph. I am using a 16f628a. Port b outputs are a ok and working a treat. As you can see by lines 4 & 5 I have set my 'a' ports as standard I/O (or so I thought). However whenever I try to set two 'a' ports high at the same time only one will go high.
    Does anyone know how to make the 'a' ports on a 16f628a act like normal old good old 84a I/O ports.
    I have attached the code and a pinout for the Bargraph. Please ignore the fact that the first loop excludes any following code from being run--this loop is a late edition for debugging only.
    http://www.picbasic.co.uk/forum/showthread.php?t=562
    http://www.picbasic.co.uk/forum/showthread.php?t=561
    These are from the FAQ - Frequently Asked Questions section, read them and see if it helps. Basically You will need to MAKE the pins NORMAL.
    If you still have problems let us know.
    first thing to understand why it doesn't work, is to open the datasheet and look what the 628 have that the 84 don't.
    Now you discover that the F628 it have analog comparator on PORTA. WOOOOHOOO, but it doesn't solve the problem yet.
    Before using those pins as regular i/o, you need to set them as digital.
    Find the Analog comparator section in the datasheet, and look the CMCON settings.
    Now you understand that you'll need to use...
    CMCON=7
    at the top of your code.
    HTH
    EDIT: oups, i'm late
    Jul 2007
    Question First thing I did.
    Thanks for the help but no joy. I already knew about the port 'a' comparator story.. hence lines 4&5 of my code
    movlw 7
    movwf CMCON
    I understand that as having the same effect as CMCON=7 (I even tried changing a couple of nights ago just to check). As long as only one port needs to be high there is no problem it is only when two or more want to be high simultaneously??? I am really frustrated as this was for a birthday present which is kind of due tomorrow??
    can you post your whole code here?
    If you do it in asm, make sure you're in the right BANK first.. unless, you may have no joy at all. BANKSEL comes handy... IN 100% ASM ONLY. If you're using a mix of PBP and assembler, you NEED to use
    CHK?RP CMCON
    instead of BANKSEL.
    HEY, wait a minute... the code you posted in your first post is not PBP, but something close to ASM and BASIC??? What is it?
    Sure it's based on Skimask's wishes
    Mister_E,
    Look at the first post. Attachments are there now.
    Jul 2007
    Default Thanks for the help...still dazed and confused
    That's the only assembly routine I have in the code. It's all attached but if you need I'll include in the body of a post. Yeah Dave (Don't know what was happening there with attachments...thanks again). Anyway I tried CMCON=7 and CMCON=%00000111. When the code hits "high l9:high l11ause 3:"..l9 flashes (almost imperceptibly) then l11 goes high. When it gets to the next section ('High l10:low l11:high l12) then l10 goes high and l12 does nothing!!
    what happen if you remove all those colon in your code???
    Pause 3, seems really fast so far... 300 could be more interesting.
    Not sure of those multiple...
    L12 refer to RA.4, and it's an open drain type. You can't drive a LED as you wish. At least, you could drive it if it's connected between Vdd, and the PIC, not between GND and PIC
    Hey, you got attachments!!
    The
    movlw 7
       movwf CMCON
    is assembly. if you are going to write it that way you need to let the program know .
    movlw 7
       movwf CMCON
    Jul 2007
    Default ra4 allocation
    Sorry, forgot to fix that...I only did that as another debug...original code was
     symbol l9= porta.0
    symbol l10= porta.1
    symbol l11= porta.2
    symbol l12= porta.3
    I reallocated to see if it was a problem with ra0 as it was the original playup pin. I have now set it back!! As far as some complimentary others not etc. If you look at the LED setup for the Bargraph hardware some (ie l1, l4, l9 and l12) are standalone LEDs whereas (l2,l3...l5,l6...l7,l8...and l10,l11) are wired in sequence. This means if I want to light LED 1 I send l1 high. If I want to light LED 2 I have to send l2 high and l3 low etc.
    Quote Originally Posted by Robotica1 View Post
    Right, but
    high l9:high l11:pause 3:
    	  low l9:low l11
    	  high l10:low l11:high l12:pause 3:
    	  low l10:low l12
    But something does not look right in the above.
    Possible to have a schematic? Picture worth thousands words
    an yup, i feel it could be done in few code lines. i bet on 50% reduction here, maybe more...
  1. port config.
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 25th July 2008, 13:25
  2. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 18:27
  3. Notebook Com Port win2k problems
    By folkc in forum Serial
    Last Post: - 20th February 2006, 17:16
  4. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 16:21
  5. Port pin problems
    By sgreelish in forum mel PIC BASIC Pro
    Last Post: - 8th March 2004, 19:56
