High Voltage Danger? When?
Results 1 to 15 of 15
Threaded View
  1. #10
    Italy
    The current flowing through your body is determined by
    the electrical resistance of the body and the voltage
    applied.
    Best regards,
    Luciano
    Amount of Body Resistance.
    Your body resistance varies greatly in different parts of your body.
    A value of 1500 ohms is commonly used as the resistance between major
    extremities of an average human body: hand to hand, or hand to foot.
    Let’s use Ohm’s Law to figure how much current would flow through
    your body if you accidentally grabbed a wire carrying 120 volts
    alternating current (vac).
    Ohm’s Law for figuring current is I = E/R.
    Let E = 120 VAC— The voltage you grabbed
    Let R = 1500 Ohms—Your (average) body resistance
    Now let’s compute it:
    I = 120/1500 = .080 amperes (80 milliamperes).
    I = 80 milliamperes. So if you grabbed a 120-vac wire, 80 milliamperes
    of current would flow through your body.
    Human reaction (at 60Hz)
    1.1 milliamperes: PERCEPTION - A slight tingling sensation.
    10 milliamperes: CAN'T LET GO - Arm and hand muscles close involuntarily. (120 lb. person).
    16 milliamperes: CAN'T LET GO (175 lb. person).
    18 milliamperes: CAN'T BREATHE - Paralysis of the chest muscles.
    65 milliamperes: HEART FIBRILLATION - Rapid irregular contractions of the heart muscles. (Could be fatal).
    Now use the above table to determine the effect of 80 milliamperes
    of electric shock. You can see that you may not be around long enough
    to grab any more wires. You grabbed 80 milliamps of current!
    That’s 15 milliamps beyond what could be fatal. It’s also 70 milliamps
    beyond the can’t- let-go threshold, and 62 milliamps beyond what
    is needed to cause you to stop breathing. It’s important to remember that
    the 1500 ohms is just an average value. Body resistance varies from
    person to person and may often be LESS than 1500 ohms. When your
    skin is moist, your body resistance could be as low as 300 ohms. Also, breaks
    in your skin at the point of contact reduce your skin resistance to nearly
    zero. Skin resistance is only important when you’re handling voltages of
    less than 240 volts. If you get shocked by more than 240 volts, the voltage
    arc will burn through your skin and leave deep third-degree bums where it
    enters your body.
    Time of Current Flow.
    The longer you’re being shocked, the more chance there is for your heart to
    begin fibrillation. Fibrillation is the shocking of your heart into a useless
    flutter. Most people who die from electric shock die from fibrillation.
    Fibrillation in a normal adult is unlikely if the current in milliamperes is
    less than 116/t, where t is the shock duration in seconds. The longer you
    are shocked, the less current is needed to cause heart fibrillation. Here are
    some examples of shock current levels and durations that would cause fibrillation:
    21 milliamperes for 30 seconds
    44 milliamperes for 7 seconds
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. high voltage high frequency H-Bridge
    By George in forum Off Topic
    Last Post: - 27th April 2009, 12:50
  3. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  5. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
