PIC16F688 Timer1
Results 1 to 6 of 6
    Quote Originally Posted by jmbanales21485 View Post
    Darryl,
    Thank you for that info. I will try it out as soon as i have a chance.
    Don't forget about Bruce's suggestion. You'll need that too.
    I only wish i knew how to program in assembly. i see that code and all i see is gibberish.
    And that's the way it'll stay, until you break down and try it.
    The hardest part about Assembly Language, is getting past the fear of something you don't already know.
    See how the changes work for you, and if there are timing problems, we can set you up with Instant Interrupts, and a couple very small ASM routines.
    Once you see how easy it is, you'll slap yourself for not trying it sooner.
    thank you both. i got my timers working fine. i am able to use tmr0 and tmr1 in my project. even though i could not get a resultion of 65us i was able to get a good reading at 100us which i think should be good enough for what i need.
    as for the ASM, your right. i do need to sit there for a day or 2 to figure out ASM and all it is is my lazyness. maybe when i really need to learn it i'll sit there and learn it. but for now im good.
    thank you all for your help.
    jose
  1. Software PWM using Timer1
    By muqasim in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 11:49
  2. Help with TIMER1 + SLEEP
    By Yodoad in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 15:07
  3. Time Period of Timer1
    By arnol34 in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 00:31
  4. Timer1 and Interupt wierdness
    By mind in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2005, 01:24
  5. Use of Timer1 with 16F819
    By Barry Johnson in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 16:25
