Pic12f675
Results 1 to 3 of 3
Thread: Pic12f675
    Jul 2007
    Default Pic12f675
    At first, sorry if this is wrong place. I´m PICBASIC newbie and my English sucks.
    I´m writing some code, and they work as I expect most of the time.
    Folows the code:
            Device 12F675
            Config CPD_OFF, CP_OFF, BODEN_OFF, MCLRE_OFF, PWRTE_ON, WDT_OFF, INTRC_OSC_NOCLKOUT
       		XTAL = 4
    		CMCON = 7 ' Desliga a função do comparador
    '1 |Vdd	                   Vss| 8
    '2 |GPIO.5         GPIO.0/ANS0| 7
    '3 |GPIO.4/ANS3    GPIO.1/ANS1| 6
    '4 |GPIO.3/MCLR    GPIO.2/ANS2| 5
    ' ANSEL register's bits
            Symbol ANS0 = ANSEL.0
            Symbol ANS1 = ANSEL.1
            Symbol ANS2 = ANSEL.2
            Symbol ANS3 = ANSEL.3
            Symbol ADCS0 = ANSEL.4		' ADC conversion clock select bit
            Symbol ADCS1 = ANSEL.5		' ADC conversion clock select bit
            Symbol ADCS2 = ANSEL.6		' ADC conversion clock select bit
    ' ADCON0 register's bits
            Symbol ADFM = ADCON0.7
            Symbol VCFG = ADCON0.6
            Symbol CHS2 = ADCON0.4		' ADC channel select bit
    		Symbol CHS1 = ADCON0.3		' ADC channel select bit
    		Symbol CHS0 = ADCON0.2		' ADC channel select bit
    		Symbol GO_DONE = ADCON0.1	' ADC Conversion status/ plus enable conversion-bit
    		Symbol ADON = ADCON0.0		' ADC Enable bit: 1 = enabled, 0 = disabled.
    		TRISIO = %001011 ' output (0)
                             ' GPIO.3 é somente input (1) digital
                             ' input (1)
    		ANSEL.0 = 1 ' ANS0 input analogic
    		ANSEL.1 = 1 ' ANS1 input analogic
    		ANSEL.2 = 0 ' ANS2 input digital
    		ANSEL.3 = 0 ' ANS3 input digital
    		SERIAL_BAUD = 9600
    		RSOUT_PIN = GPIO.2
    		RSOUT_MODE = TRUE
    		RSOUT_PACE = 10
    		ADIN_Res 10
    		ADIN_TAD FRC
    		ADIN_STIME 50
    		Symbol LANTERNA = GPIO.4   	' Alias PORTD to LEDS
        	Symbol FAROL = GPIO.5
    '-------[ASSIGN A VARIABLE FOR THE ADC RESULT]---------------------------
            Dim AD_RESULT as ADRESL.WORD	' Convert the ADRESL register into a WORD variable
            Dim mySet as Word
            Dim myAtual as Word
            Dim myCh AS BYTE
            VCFG = 0						' VREF is set to VDD of PICmicro
            ADFM = 1						' Right justify the ADC result
    		Delayms 500				' Wait for PICmicro to stabilise
    		LANTERNA = 0
    		FAROL = 0
    Loop:
            MyCh = 0
            Gosub Plota_ADC
            mySet = AD_result
            DelayMS 500
            myCh = 1
            gosub PLOTA_ADC
            myAtual = Ad_result
            if mySet <= myAtual then
               FAROL = 1
            Else
                FAROL = 0
            end if
            DelayMS 500
            Goto Loop       		' Go back to loop and blink LED forever
    PLOTA_ADC:
            WARNINGS = OFF
            BYTE_MATH = On                 ' Enable expression optimisation
            ADCON0 = ADCON0 | (myCh << 2)  ' Select the channel to read --> ADCON0 = ADCON0 | (nro. canal << 2 )
            BYTE_MATH = OFF				   ' Disable expression optimisation
            WARNINGS = On
            AD_RESULT = ADIN myCh          ' faz a leitura do canal myX
            RSOut At 1,1,"ADC CHANNEL ", DEC myCh, " ", Dec AD_Result, 13 ' Display the result serially
    My problem is when RSOut was processed, if the FAROL is HIGH they go down and the corresponding LED turn off.
    Can anyone help me?
    Quote Originally Posted by perides View Post
    Can anyone help me?
    Wrong forum...
    Proton Basic (or whatever it is) <> PicBasicPro...as the top of this page says.
    Jul 2007
    Again, sorry. Both Basics are very close to me.
    I´ll try to find help in correct place. May the administrator can erase my post.
  1. PIC12F675 problem with port 5
    By NL2TTL in forum mel PIC BASIC
    Last Post: - 5th June 2009, 02:23
  2. SMS with pic12f675 using Serout
    By camilen in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 21:16
  3. SERIN with a PIC12F675
    By ewandeur in forum Serial
    Last Post: - 30th July 2007, 16:04
  4. PIC12F675 trouble
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 19:40
  5. Erratic PIC12F675 behavior
    Last Post: - 27th February 2006, 15:46
