Pic12f683 Cmcon0 = 7
Results 1 to 26 of 26
    Posts #20 and #23 of this thread... and you're almost there... it's real simple... add to that the ADCIN section of your PBP Manual and the ADC Section of your chosen PICs Datasheet.
    Lesson 1.
    Get a PIC with ADC Input capability and enough pins to drive an LCD Display. Hook it up so you can send messages to your LCD. Put a POT (10K or 5K) across your 5v supply with the wiper to the PIC ADC pin. Write a small program to display what the ADC value is when reading 8-bit. Wind the POT up and down a few times to see digits change...
    Lesson 2.
    Repeat above with 10-bit ADC input.
    You're an expert!
    Melanie,
    OK, I contacted my supplier rep and he's sampling me some LCD screens and driver ICs. He gasped and said "Wow, you're finally going digital!"
    I also went a step further and ordered the book, Programming PIC Microcontrollers with PICBASIC. Something that I should have done a long time ago.
    Thanks again!
    ~ Dave
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  3. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  4. Working with indivividual bytes of an array
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2007, 20:16
  5. code conversion
    By saturnX in forum mel PIC BASIC
    Last Post: - 3rd October 2005, 18:17
