Pic12f683 Cmcon0 = 7
Results 1 to 26 of 26
    OK, the penny's dropped...
    mon = 16 bits, whilst width = 8 bits... you can't put a quart into a pint pot...
    try...
    width = mon/4
    In case you're wondering why /4 instead of /8... that's because your ADC reading is 10 bits. So why not read 8-bit ADC to start with?
    try...
    width = mon/4
    Because I'm such a noob that I have no idea how to do that. Now I'm really confused.
    So with this change, when the IC reads less than 2 volts on "mon" it should execute hpwm 1,255,2000; more than 2 volts and it should execute 1,32,2000?
    ~ Dave
    Looks like we have a lot to learn here...
    No, it WON'T be two volts....
    The ADC returns a number between zero and 1023 (because you are in 10-bit mode), where zero equals 0v on the ADC, and 1023 equals full-scale 5v on the ADC. Each click on the ADC scale represents 1/1023 ie a FRACTIONAL part of 5v.
    So if 5v = 1023, then 2v will be two fifths of 1023 (namely 409).
    So, if you want the trip point to be 2v and with a 10-bit ADC, your code should be...
        ADCIN 3, mon ' Read channel AN3 to Mon
        if mon > 409 then
    	hpwm 1,32,2000
    	hpwm 1,255,2000
        if mon > 409 then
    	hpwm 1,32,2000
    	hpwm 1,255,2000
    Wow, it's no wonder I was frustrated enough to chew the lips off of a carp!
    OK, where is it that I look up the ins and outs of 8 bit, 10 bit and such? I'd love to find a PBP book for Dummies or something like it.
    Thanks again Melanie!
    ~ Dave
    try...
    width = mon/4
    So, if I would have used Define ADC_BITS 8, I would have been OK?
    ~ Dave
    Well, in that case with 8 bit ADC, variable mon should be a BYTE rather than a WORD.
    Your ADC range for 0-5v is an ADC reading of 0-255 where 255=5v.
    So 2 volts will be 2/5ths of 255 namely 102...
    So the IF statement then becomes IF mon > 102 THEN...
    The decision to use 8-bit or 10-bit ADC is simply a matter of precision, and you chose whether you need steps of 1/255 or 1/1024 for the ADC span that you are using.
    Melanie,
    1/255 is fine.
    Where can I go to learn the basics of using AD conversions? It's obvious that I have no clue.
    Thanks again for the help.
    ~ Dave
    Posts #20 and #23 of this thread... and you're almost there... it's real simple... add to that the ADCIN section of your PBP Manual and the ADC Section of your chosen PICs Datasheet.
    Lesson 1.
    Get a PIC with ADC Input capability and enough pins to drive an LCD Display. Hook it up so you can send messages to your LCD. Put a POT (10K or 5K) across your 5v supply with the wiper to the PIC ADC pin. Write a small program to display what the ADC value is when reading 8-bit. Wind the POT up and down a few times to see digits change...
    Lesson 2.
    Repeat above with 10-bit ADC input.
    You're an expert!
    Melanie,
    OK, I contacted my supplier rep and he's sampling me some LCD screens and driver ICs. He gasped and said "Wow, you're finally going digital!"
    I also went a step further and ordered the book, Programming PIC Microcontrollers with PICBASIC. Something that I should have done a long time ago.
    Thanks again!
    ~ Dave
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  3. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  4. Working with indivividual bytes of an array
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2007, 20:16
  5. code conversion
    By saturnX in forum mel PIC BASIC
    Last Post: - 3rd October 2005, 18:17
