Problem in Tension/compression
Results 1 to 18 of 18
    Mar 2006
    INDIA
    When counts cross 65535, number will be 00000 and counts again upto 65535
    but when i code
    if W0 < 0 then W0 = 65535 + 1
    after this counter will 00000 and hang on 00001
    Quote Originally Posted by precision View Post
    but when i code
    That's my point...
    W0 cannot be less than 'ZERO' with PBP...
    PBP does not natively handle negative numbers using normal math routines. Yes there are a few commands that can handle signed integers, but not in the way you're looking to handle them. There are no 'minus' signs
    You must figure out your own method to handle those negative numbers.
    precision,
    Give this a try.
    DEFINE OSC 20
    INCLUDE "MODEDEFS.BAS"
    INCLUDE "MYLCD.BAS"
    ANSEL = 0 'SELECT ANALOG INPUTS 0 = NONE AND ALL DIGITAL
    ADCON0 = 0 'AD MODULE OFF & CONSUMES NO CURRENT
    CMCON = 7 'COMPARATORS OFF
    TRISA = %00000
    TRISB = %00000011  ' INT0 = ENCODER CH. A
                       ' PORTB.1 = ENCODER CH. B
    W0     VAR WORD
    LastW0 VAR WORD
    B1     var word
    W0 = 0
    B1 = 0
    PAUSE 500
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
            INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
    OPTION_REG.6 = 0   ; 1 = Interrupt on rising edge of INT pin
                       ; 0 = Interrupt on falling edge of INT pin
    @   INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    LCDOUT $FE,1
    LOOP:
            IF W0 <> LastW0 then
                LastW0 = W0
                     ' (Peak-Hold), Hold the last value of W0 in B1
                if ABS(LastW0) > ABS(B1) then B1 = LastW0
                LCDOUT $FE,2
                LCDOUT "Length = ", Sdec LastW0, " mm    "
                lcdout $FE, $C0
                lcdout "Peak- Value ",Sdec B1, " mm    "
    GOTO LOOP
    ToggleLED1:
            if PORTB.1 = 0 then
                W0 = W0+1
                w0 = w0-1
    @ INT_RETURN
    The range will be +/-32767.
    Added: Modified slightly to eliminate changes while displaying.
    Modified again to simplify. ABS() works for both pos and neg numbers. Doh!
    It also fixes a problem if it moves slightly negative before going positive.
    I'll get it right one of these times
    Just posting this for an email notification that I changed the program above.
    In case you're already trying it.
    Mar 2006
    INDIA
    Sir Darrel Taylor
    Peak-hold now working well for both side.
    But my problem is , i want to counting down side 0 to 1 ,2 , 3 ......... ( not 65535, 65534 , 65533 .......)
    You might want to just try the whole program I posted, instead of making the changes to yours. Because I think you've missed something.
    With the SDEC modifier in the lcdout statements, it will read -1, -2, -3 etc. And will never show 65535.
    There are several other subtle changes too.
    <DT>
    Mar 2006
    INDIA
    Thanks it is work on lcd.
    but on 7 seg. LED display , it is not work in +/- ,
    this is my code
    ; CHIP 18F4550
    DEFINE OSC 20
    CMCON = 7
    ADCON1 = 15
    CVRCON = %00000000 'CVref turned off
    TRISE = %000
    TRISA = 11111
    TRISB = %11111111
    TRISC = %11111111
    TRISD = %11111111
    Symbol HC_latch = PORTE.2
    symbol HC_Data = PORTE.1
    SYMBOL HC_Clk = PORTE.0
    B1 VAR BYTE
    B2 VAR BYTE
    B3 VAR BYTE
    B4 VAR BYTE
    B5 VAR BYTE
    B6 VAR WORD
    W0 VAR WORD
    w3 var word
    DUMMY VAR WORD
    DIGIT1 VAR BYTE
    DIGIT2 VAR BYTE
    DIGIT3 VAR BYTE
    DIGIT4 VAR BYTE
    DIGIT5 VAR BYTE
    DIGIT6 VAR BYTE
    W1 VAR WORD
    MASK VAR WORD
    LastW0 VAR WORD
    B1 = 0
    B2 = 0
    B3 = 0
    B4 = 0
    B5 = 0
    W1 = 0
    W0 = 0
    w3 = 0
    E1 VAR BYTE
    E2 VAR BYTE
    E3 VAR BYTE
    E4 VAR BYTE
    E5 VAR BYTE
    PAUSE 500
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
            INT_Handler    INT0_INT,  _ToggleLED1,   PBP,  yes
    @   INT_ENABLE   INT0_INT     ; enable external (INT) interrupts@   INT_ENABLE   INT1_INT     ; enable external (INT) interrupts
    LOOP:
             LastW0 = W0
             if ABS(LastW0) > ABS(w3) then w3 = LastW0
            B1 = LastW0 DIG 0
            B2 = LastW0 DIG 1
            B3 = LastW0 DIG 2
            B4 = LastW0 DIG 3
            B5 = LastW0 DIG 4
              DIGIT1 = B1
            LOOKUP DIGIT1,[$C0,$F9,$A4,$B0,$99,$92,$82,$F8,$80,$90],MASK
            E1 = MASK
            DIGIT2 = B2
            LOOKUP DIGIT2,[$C0,$F9,$A4,$B0,$99,$92,$82,$F8,$80,$90],MASK
            E2 = MASK
             DIGIT3 = B3
            LOOKUP DIGIT3,[$C0,$F9,$A4,$B0,$99,$92,$82,$F8,$80,$90],MASK
            E3 = MASK
             DIGIT4 = B4
            LOOKUP DIGIT4,[$C0,$F9,$A4,$B0,$99,$92,$82,$F8,$80,$90],MASK
            E4 = MASK
            DIGIT5 = B5
            LOOKUP DIGIT5,[$C0,$F9,$A4,$B0,$99,$92,$82,$F8,$80,$90],MASK
            E5 = MASK
             HC_Latch=0
            shiftout HC_data, HC_Clk, MSBFIRST,[E1,E2,E3,E4,E5,$C0]
            pauseus 1
            HC_Latch=1
             GOTO LOOP
    ToggleLED1: if PORTB.1 = 0 THEN
                  W0 = W0 + 1
                  W0 = W0 - 1
            @ INT_RETURN
  1. USART Problem , but don't know where, in pc? or in PIC?
  2. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  3. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:39
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
  5. PORTA.PinNo = 1 ' problem
    By frank small in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 15:30
