Problem in Tension/compression
Results 1 to 18 of 18
Threaded View
  1. #5
    precision,
    Give this a try.
    DEFINE OSC 20
    INCLUDE "MODEDEFS.BAS"
    INCLUDE "MYLCD.BAS"
    ANSEL = 0 'SELECT ANALOG INPUTS 0 = NONE AND ALL DIGITAL
    ADCON0 = 0 'AD MODULE OFF & CONSUMES NO CURRENT
    CMCON = 7 'COMPARATORS OFF
    TRISA = %00000
    TRISB = %00000011  ' INT0 = ENCODER CH. A
                       ' PORTB.1 = ENCODER CH. B
    W0     VAR WORD
    LastW0 VAR WORD
    B1     var word
    W0 = 0
    B1 = 0
    PAUSE 500
    INCLUDE "DT_INTS-14.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP.bas"     ; Include if using PBP interrupts
            INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
    OPTION_REG.6 = 0   ; 1 = Interrupt on rising edge of INT pin
                       ; 0 = Interrupt on falling edge of INT pin
    @   INT_ENABLE   INT_INT     ; enable external (INT) interrupts
    LCDOUT $FE,1
    LOOP:
            IF W0 <> LastW0 then
                LastW0 = W0
                     ' (Peak-Hold), Hold the last value of W0 in B1
                if ABS(LastW0) > ABS(B1) then B1 = LastW0
                LCDOUT $FE,2
                LCDOUT "Length = ", Sdec LastW0, " mm    "
                lcdout $FE, $C0
                lcdout "Peak- Value ",Sdec B1, " mm    "
    GOTO LOOP
    ToggleLED1:
            if PORTB.1 = 0 then
                W0 = W0+1
                w0 = w0-1
    @ INT_RETURN
    The range will be +/-32767.
    Added: Modified slightly to eliminate changes while displaying.
    Modified again to simplify. ABS() works for both pos and neg numbers. Doh!
    It also fixes a problem if it moves slightly negative before going positive.
    I'll get it right one of these times
  1. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  2. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 21:04
  3. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 21:39
  4. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
  5. PORTA.PinNo = 1 ' problem
    By frank small in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 14:30
