How do you know your PIC is not working?
Consider the test code below...
If your 555 is running at 100kHz it would actually take 40 seconds before the LED lit (with PBP set to a 4MHz default - unless you've told it otherwise). What speed is your 555 running at? Is it running? Have you remembered to tie MCLR to Vdd or otherwise set it to internal?Code:LED var PortB.0 TRISB=%00000000 loop: Pause 1000 Toggle LED Goto Loop End
