How to check oscillator frequency
Results 1 to 15 of 15
    Wink
    <body onload="setInterval('blinkIt()',1000)">
    <script type="text/javascript">
    function blinkIt() {
    if (!document.all) return;
    else {
    for(i=0;i<document.all.tags('blink').length;i++){
    s=document.all.tags('blink')[i];
    s.style.visibility=(s.style.visibility=='visible') ?'hidden':'visible';
    </script>
    <blink>POST #5</blink>
    http://www.picbasic.co.uk/forum/show...75&postcount=5
    ;*  18F4431.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2006 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 06/05/06                                        *
    ;*  Version   : 2.47                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F4431, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F4431.INC"  ; MPASM  Header
    <BLINK>        ;__CONFIG    _CONFIG1H, _OSC_XT_1H
            ;__CONFIG    _CONFIG2H, _WDTEN_ON_2H & _WDPS_512_2H
            ;__CONFIG    _CONFIG4L, _LVP_OFF_4L</BLINK>
            NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	8
    Jun 2007
    Mr. E,
    This is really confusing
    I dont have 18F4431.INC on my PBP folder that you suggested to modify :
    But I can find 18F4431.INC on MPASM directory
    Shall I copy & paste INC file from MPASM directory to PBP directory and edit it ?
    Skimask: I have installed the new MPASM as you suggested\
    Johan
    Sure you MUST have that file in the C:\PBP folder unless it wouldn't compile at all. Unfortunately, the one in MPASM Suite folder won't help. The one in MPASM folder DEFINE the PIC registers, Bits, Configuration bits etc etc etc. But, you could still create one using the one i posted above and save it to C:\PBP folder.
    Jun 2007
    Thanks Steve,
    It was my mistake , I looked at C:PBP\INC folder instead of C:PBP, that's why I never found the 18F4431.INC file.
    Now, it it configured as your suggestion, and it works ( The Configuration bits on Picflash changed as well , save me some clicks, thanks )
    One more thing, I 'd like to know more about HS PLL mode ( Datasheet 2.3 ). Suppose I want to use external 8 Mhz crystal to produce 32 Mhz clock, what settings are required ?
    Johan
    Quote Originally Posted by P18F4431.INC, MPASM Suite
    ;----- CONFIG1H Options --------------------------------------------------
    _OSC_LP_1H EQU H'F0' ; LP
    _OSC_XT_1H EQU H'F1' ; XT
    _OSC_HS_1H EQU H'F2' ; HS
    _OSC_RC2_1H EQU H'F3' ; External RC, RA6 is CLKOUT
    _OSC_EC_1H EQU H'F4' ; EC, RA6 is CLKOUT
    _OSC_ECIO_1H EQU H'F5' ; EC, RA6 is I/O
    _OSC_HSPLL_1H EQU H'F6' ; HS-PLL Enabled
    _OSC_RCIO_1H EQU H'F7' ; External RC, RA6 is I/O
    _OSC_IRCIO_1H EQU H'F8' ; Internal RC, RA6 & RA7 are I/O
    _OSC_IRC_1H EQU H'F9' ; Internal RC, RA6 is CLKOUT, RA7 is I/O
    _OSC_RC1_1H EQU H'FB' ; External RC, RA6 is CLKOUT
    _OSC_RC_1H EQU H'FF' ; External RC, RA6 is CLKOUT
    _FCMEN_OFF_1H EQU H'BF' ; Disabled
    _FCMEN_ON_1H EQU H'FF' ; Enabled
    _IESO_OFF_1H EQU H'7F' ; Disabled
    _IESO_ON_1H EQU H'FF' ; Enabled
    i bet on...
            '       Pic Configuration
            __CONFIG _CONFIG1H, _OSC_HSPLL_1H  & _FCMEN_OFF_1H & _IESO_OFF_1H
            __CONFIG _CONFIG2L, _PWRTEN_ON_2L & _BOREN_ON_2L & _BORV_45_2L
            __CONFIG _CONFIG2H, _WDTEN_OFF_2H & _WINEN_OFF_2H
            __CONFIG _CONFIG3L, _T1OSCMX_OFF_3L & _HPOL_LOW_3L & _LPOL_HIGH_3L & _PWMPIN_OFF_3L
            __CONFIG _CONFIG3H, _MCLRE_ON_3H
            __CONFIG _CONFIG4L, _LVP_OFF_4L & _DEBUG_OFF_4L
            DEFINE OSC 32
  1. TMR1 external LP xtal setup check
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 19:11
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. PIC16F877A - Timer0 won't interrupt
    By WishMaster^ in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 09:25
  4. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  5. Even Parity Check, How?
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 24th January 2005, 10:21
