How to check oscillator frequency
Results 1 to 15 of 15
Threaded View
  1. #4
    yeah... it run but the default OSC speed is set to 32KHz
    just add those
    OSCCON= %01100000       ' configure internal OSC  @ 4MHZ
    While OSCCON.2=0 : wend ' wait until OSC is stable
    at the top of your code.
    For the configuration bits, it's usual and recommended to set them in your code, have a look at the following...
    and here's a short example for a 18F2431, as inspiration source
            '       Pic Configuration
            __CONFIG _CONFIG1H, _OSC_IRCIO_1H  & _FCMEN_OFF_1H & _IESO_OFF_1H
            __CONFIG _CONFIG2L, _PWRTEN_ON_2L & _BOREN_ON_2L & _BORV_45_2L
            __CONFIG _CONFIG2H, _WDTEN_OFF_2H & _WINEN_OFF_2H
            __CONFIG _CONFIG3L, _T1OSCMX_OFF_3L & _HPOL_LOW_3L & _LPOL_HIGH_3L & _PWMPIN_OFF_3L
            __CONFIG _CONFIG3H, _MCLRE_ON_3H
            __CONFIG _CONFIG4L, _LVP_OFF_4L & _DEBUG_OFF_4L
    Now if you want to switch to the external OSC, use...
            __CONFIG _CONFIG1H, _OSC_HS_1H  & _FCMEN_OFF_1H & _IESO_OFF_1H
            DEFINE OSC 8
    and remove the OSCCON & WHILE : WEND lines
  1. TMR1 external LP xtal setup check
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 19:11
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. PIC16F877A - Timer0 won't interrupt
    By WishMaster^ in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 09:25
  4. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  5. Even Parity Check, How?
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 24th January 2005, 10:21
