Use 0 if your four data lines are RA0-RA3
Use 4 if your four data lines are RA4-RA7 (but this will not work as noted above)
If you still have issues, you might want to post a schematic and the rest of your code (if there is more) - more and better info usually means more and better help
Good Luck
