At first, sorry if this is wrong place. I´m PICBASIC newbie and my English sucks.
I´m writing some code, and they work as I expect most of the time.
Folows the code:
My problem is when RSOut was processed, if the FAROL is HIGH they go down and the corresponding LED turn off.Code:Device 12F675 Config CPD_OFF, CP_OFF, BODEN_OFF, MCLRE_OFF, PWRTE_ON, WDT_OFF, INTRC_OSC_NOCLKOUT XTAL = 4 CMCON = 7 ' Desliga a função do comparador ' +--------------------------+ '1 |Vdd Vss| 8 '2 |GPIO.5 GPIO.0/ANS0| 7 '3 |GPIO.4/ANS3 GPIO.1/ANS1| 6 '4 |GPIO.3/MCLR GPIO.2/ANS2| 5 ' +--------------------------+ ' ANSEL register's bits Symbol ANS0 = ANSEL.0 Symbol ANS1 = ANSEL.1 Symbol ANS2 = ANSEL.2 Symbol ANS3 = ANSEL.3 Symbol ADCS0 = ANSEL.4 ' ADC conversion clock select bit Symbol ADCS1 = ANSEL.5 ' ADC conversion clock select bit Symbol ADCS2 = ANSEL.6 ' ADC conversion clock select bit ' ADCON0 register's bits Symbol ADFM = ADCON0.7 Symbol VCFG = ADCON0.6 Symbol CHS2 = ADCON0.4 ' ADC channel select bit Symbol CHS1 = ADCON0.3 ' ADC channel select bit Symbol CHS0 = ADCON0.2 ' ADC channel select bit Symbol GO_DONE = ADCON0.1 ' ADC Conversion status/ plus enable conversion-bit Symbol ADON = ADCON0.0 ' ADC Enable bit: 1 = enabled, 0 = disabled. TRISIO = %001011 ' output (0) ' GPIO.3 é somente input (1) digital ' input (1) ANSEL.0 = 1 ' ANS0 input analogic ANSEL.1 = 1 ' ANS1 input analogic ANSEL.2 = 0 ' ANS2 input digital ANSEL.3 = 0 ' ANS3 input digital SERIAL_BAUD = 9600 RSOUT_PIN = GPIO.2 RSOUT_MODE = TRUE RSOUT_PACE = 10 ADIN_Res 10 ADIN_TAD FRC ADIN_STIME 50 Symbol LANTERNA = GPIO.4 ' Alias PORTD to LEDS Symbol FAROL = GPIO.5 '-------[ASSIGN A VARIABLE FOR THE ADC RESULT]--------------------------- Dim AD_RESULT as ADRESL.WORD ' Convert the ADRESL register into a WORD variable Dim mySet as Word Dim myAtual as Word Dim myCh AS BYTE VCFG = 0 ' VREF is set to VDD of PICmicro ADFM = 1 ' Right justify the ADC result Delayms 500 ' Wait for PICmicro to stabilise LANTERNA = 0 FAROL = 0 Loop: MyCh = 0 Gosub Plota_ADC mySet = AD_result DelayMS 500 myCh = 1 gosub PLOTA_ADC myAtual = Ad_result if mySet <= myAtual then FAROL = 1 Else FAROL = 0 end if DelayMS 500 Goto Loop ' Go back to loop and blink LED forever End PLOTA_ADC: WARNINGS = OFF BYTE_MATH = On ' Enable expression optimisation ADCON0 = ADCON0 | (myCh << 2) ' Select the channel to read --> ADCON0 = ADCON0 | (nro. canal << 2 ) BYTE_MATH = OFF ' Disable expression optimisation WARNINGS = On AD_RESULT = ADIN myCh ' faz a leitura do canal myX RSOut At 1,1,"ADC CHANNEL ", DEC myCh, " ", Dec AD_Result, 13 ' Display the result serially Return
Can anyone help me?
