7-segment display with P16F84
Results 1 to 17 of 17
    Jul 2007
    Default 7-segment display with P16F84
    Hi all, I am new to PIC's but have been studying electronics for 3 years and work as a technician.
    I recently came across this site http://www.melabs.com/resources/articles/ledart.htm
    with instruction on how to run 7-segment display, i have built the circuit and programmed the PIC with this code: http://www.melabs.com/resources/samp...p/7segment.pbp
    but the numbers run really fast and display 0 runs too fast to read it, I have tried adding a PAUSE 1000 under "mainloop" and just below GOSUB display but it only make the displays flash on and off
    I am trying to get them to display a number for atleast 1 second each or atleast make it so i can read digit 0
    PS I have tried contacting the site but they never got back to me.
    Thanks is advance.
    once I get this working and learn a little more I plan on adding push buttons and making it into a stopwatch or either a countdown timer.
    Raf
    Bombay, India
    i	Var	Byte
    n	Var	Byte
    Value	Var	Word
    	TRISB = $80		' Set segment pins to output
    	TRISA = $f0		' Set digit pins to output
    mainloop:
    	For Value = 0 To 9999
    		GoSub display	' Display the value
    	Next Value
    	GoTo mainloop		' Do it forever
    You need to modify this patch to something like this
    i	Var	Byte
    n	Var	Byte
    Value	Var	Word
    timedelay      var        word
    mainloop:
                    for timedelay = 0 to 2000
                    next
    	Next Value
    The value you choose for the timedelay will help you persist a value for as long as you choose.
    Jerson
    Feb 2003
    Quote Originally Posted by spitfire View Post
    Thanks is advance.
    Raf
    This is the section of code you should try to alter
    display:
    	For i = 0 To 3		' Loop through 4 digits
    		n = Value Dig i	' Get digit to display
    		GoSub display1	' Display the digit
    		Pause 1		' Leave it on 1 millisecond
    	Next i			' Do next digit
    This displays each digit for 1 millisecond. try increasing the length of the pause.
    By adding your Pause 1000 in the main loop you are adding a 1 second delay between counting. The LEDs are only lit during the display subroutine so you have 4mS of display and then a second waiting to the next 4mS.
    Try a 25mS delay (PAUSE 25) or longer to make the digits more visible but you may then notice a flicker across the digits.
    Try adding another counting loop so that you only increment the 0-9999 count once every "x" passes through the main loop.
    HTH
    Keith
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Jul 2007
    Thank alot guys, I was hardly expecting such promt replys.
    I will try your suggestions out now.
    Jul 2007
    Thumbs up
    I got it working using your method Jerson by setting "for timedelay = 0 to 100", works great.
    I was wondering if someone could recomend some books or any other good sources of information for writing code?
    Cheers,
    Raf
    Hi Spitfire,
    I have bought several books, and without this forum, I would be using them as table levelers, I do not have one I would recommend. Keep reading this forum and the PBP manual, read the archives . . every post, thats waaay better than any book I've seen. Bruce is writing one though and when it is published, I will buy one.
    JS
    Dec 2006
    Does anyone know where i can get one of those 3 digit seven segment displays that are designed to be multiplexed. aka has 12 pins instead of well loads more.
  1. 7 Segment Displays and MAX7219
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 19:30
  2. Weird compile issue 7 segment LED display
    By George in forum mel PIC BASIC Pro
    Last Post: - 21st June 2006, 03:12
  3. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 21:25
  4. WRITE not working
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2004, 03:02
  5. Multiplex two 7 segment display
    By Fernando Santos in forum mel PIC BASIC Pro
    Last Post: - 20th July 2003, 14:26
