Driving a mosfet directly?
Results 1 to 22 of 22
    Look at Microchip, MCP1401 is one example. Many others exist too.
    passion1, May I suggest an IRL2505. It is a logic level fet. I have used them in the past with great success..
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    This is a great FET but it requires a large gate charge (130nC). If you are switching a lot, you would want to buffer the PIC pin as a minimum since the PIC pin cannot supply a lot of current. (i.e., it will take some time for the PIC to directly charge the gate, which means lots of FET heat if your load is high). One of the FETs recommended by Russ actually has an amazing low charge requirement and could be charge in less than a 1 uS directly by a PIC. Again, the proper answer to your question depends on what you are doing.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Omaha, Nebraska USA
    Attached is a circuit I've had repeated success with.
    I suggested the 2N7000 because of its availability, general utility and very low cost (about 0.11 USD in single quantities). It's been around a long time. Both the MTP3055V and MTP3055VL are also readily available and moderately priced (about 1.16 USD in single quantities).
    I have to echo Paul's questions:
    What kind of load are you driving?
    What current capacity do you actually need?
    How often will you be switching?
    We could probably be a lot more helpful if we knew these things!
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    New Zealand
    Pauls question is quite important - especially the how often part, if you want yr fet to pwm - then you really have to use a driver or it will just end up as a load of smoke, if it's just occasional switching you should be fine - preferably with logic level fet.
    May 2007
    Thanks guys.
    I am learning a lot here and I appreciate your help.
    Everything is starting to make sense and my own understanding of fet's is improving rapidly!
    RussMartin,George
    I am using pwm and is switching using frequencies up to 20kHz.
    Although it is not needed right now, I would like to accomodate higher voltages at a later stage
    and for that reason I have chosen the IRFP460 which can handle up to 500V and 20A.
    Right now I am trying to determine what would be the best driver (if necessary) to use with the IRFP460 specifically
    because I have already tested this mosfet to work well with my application while using lower voltages,
    and at higher voltages (e.g. 200V) I should never exceed 3amps current.
    Thanks again for all the suggestions, it really helped a lot!
    Omaha, Nebraska USA
    Okay, you've given us voltage and current requirement (up to 200V, up to 3A), and the maximum switching rate (20kHz).
    It would still be nice to know what kind of load you are switching--
    Russ
  1. Another Mosfet Question
    By tazntex in forum General
    Last Post: - 29th September 2008, 03:53
  2. Help needed - MOSFET driven by PWM
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 05:02
  3. Mosfet problems
    By Agent36 in forum General
    Last Post: - 2nd February 2008, 22:37
  4. MOSFET control using PWM & 16C711?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 02:24
  5. Driving a logic-level HEXFET
    By thelightbrain in forum mel PIC BASIC Pro
    Last Post: - 10th November 2004, 23:34
