Charles / Ioannis
Thank you for the advice.
Can I connect the mosfet source directly to the ground of a 24-36V supply, and drain goes to load with other side of load going to +36VDC?
Charles / Ioannis
You should take care if the load is noisy. Otherwise there is no problem in that connection.
Also remember that the 16F73 output is VDD-0.7VDC. If you are you using 5.0V for the PIC VDD, your max Vgs will be 4.3VDC. (Your selected FET can have a Vgs threshold of 4.0 VDC !!). You won't be able to get much IDrain Current, possibly 3A max. If it were me (with what I know about your application and what you are driving), I would switch to a FET that was more logic-level friendly like the IRL520 (or something similar). Otherwise I would look at adding a driver near 10Vdc.
By the way, what are you driving and what amperage do you need?
Paul Borgmeier
Salt Lake City, UT
USA
__________________
With a maximum Vdss of 60V, it's only rated at 12A continuous (42A pulsed) but might the MTP3055VL (Fairchild, TO220 package) or similar critter be a possible solution? Vgs(th) is less than 2V and Rds(on) is about 0.1 ohm.
Alternatively, the 2N7000 (TO92 package) makes a pretty good little MOSFET driver.
Russ
N0EVC, xWB6ONT, xWN6ONT
"Easy to use" is easy to say.
I remind that for every ampere of the Drain pin there must be an amount of Gate drive. Don't get too excited byt the great amperage that datasheets state! Read carefully!
Paul, RussMartin, Ioannis
Paul, thank you for pointing out that I won't be able to get much IDrain current.
Any suggestion for a driver near 10Vdc, apart from the 2N7000 suggested by RussMartin?
I really appreciate your help.
I didn't really point it out - Ioannis did in a post before me.
As far as a driver, it depends on what you are driving and how often. If you are switching a lot, you need something different than if you just want to turn something on once or once in a while. I'll ask again:
What you driving?
What Amperage do you need?
How often will you be switching?
Paul Borgmeier
Salt Lake City, UT
USA
__________________
