pwm help
Results 1 to 4 of 4
Thread: pwm help
    Feb 2004
    Germany
    I have just tried it and it it appears to be really weird as you don't have any control over the HPWM Port bit when the PIC is send to sleep.
    It might be HIGH or LOW at the time you send the PIC to sleep and it remains in this state until you wake the PIC up again.
    Even a HIGH "HPWMpin" or LOW "HPWMpin" right before e the "SLEEP" command doesn't help.
    So depending on what you have connected to the HPWM Pin there is a 50% chance you wouldn't save any Power at all by sending the PIC to sleep.
    let's assume you have a MOSFET on your HPWM port driving some "High Power" device there is a 50% chance that it will be instantly ON while the PIC is sleeping.
    regards
    Ralph
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM: Vernacular/Function (Newbee)
    By TerryN in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 17:58
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
