Decimal point with serout?
Results 1 to 6 of 6
    Kman,
    You almost had it.
    Just need to move the GOTO Main down 1 line, and clear the timer when it reaches 100 instead of after you Print it to the LCD/Terminal.
        SerOut2 SO,16468,["Milage = ",DEC Miles,".", DEC Tenths ,13]
    Loop:
        VSSCount = TMR0 		 ' Get TMR0 count
        IF VSSCount > 99 Then
            VSSCount = 0
            TMR0 = 0
            Tenths = Tenths + 1
            IF Tenths > 9 Then
                Tenths = 0
                Miles = Miles + 1
            EndIF
            GoTo Main
        EndIF
    GoTo Loop
    OR, you can reduce it a little so that it works with the timer directly. Get's rid of VSSCount.
    Loop:
        IF TMR0 > 99 Then
            TMR0 = 0
            Tenths = Tenths + 1
            IF Tenths > 9 Then
                Tenths = 0
                Miles = Miles + 1
            EndIF
            GoTo Main
        EndIF
    GoTo Loop
    Now you just need a way to save it to EEPROM, so you don't lose the value when power is lost.
    HTH,
    Smile
    Thanks Darrel ! Its counting away, and the decmal is in the proper Place!
    Last Post: - 8th March 2010, 21:58
  2. How do I add a decimal point?
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 14th December 2009, 12:47
  3. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
  4. Advice-scrutiny for my serial controller
    Last Post: - 13th December 2008, 18:11
  5. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
