PBP, the actual text based source code is relatively transferrable between PICs. However, at the actual binary level, trying to run code for a 16F84a on anything will get you nothing but trouble. You'll probably only have to recompile it for the PIC you want to use. At any rate, you MUST check the datasheets to see the main differences between the 2 types of PICs, the differences in the pins, differences in registers, etc. You can't just go slappin' one PICs code into another type and expect it to work.
