Help with sound command in 2 programs
Results 1 to 5 of 5
    A couple of potential problems you might want to look at:
    freq = 23*RPM + RPM/3		'Calculation of frequency
    period = (62500/freq)*16	'Calculation of period
    potential for overflow here. While the calculation 'as a whole' might not overflow, intermediate variables may overflow, if RPM is above 2849.
    		pauseus (1000*period)/cnt		'Variable pause
    same thing with these lines. If period is over 65, the intermediate variables used in calculating the pauseus value may overflow.
    I didn't even think about the overflows, what's the best way to remedy that? The RPM value will stay pretty low, usually around 60, but I can see that being a problem with the calculations.
    So I just solved the problem, it's this line:
    'Configuration Bit Definitions
    @ __config _CONFIG1, _INTRC_IO	'sets the INTRC-OSC2 as RA6
    This of course brings up new problems, I'm not 100% sure what this line does, but now I've gotta try to figure that out.
    So I figured out that the line in question enables i/o functions on RB5 and RB7, but I still need the sound command to work on RB3. I've been reading through the PIC16F88 datasheet and trying to figure out how to properly set the configuration bits to allow this, but have yet to have any luck. Any bright ideas?
  1. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 12:34
  2. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 06:28
  3. Replies: 4
    Last Post: - 15th April 2009, 01:54
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 22:40
  5. Microcontroller with 2 way paging application problem
