strange problem 12f675
Results 1 to 2 of 2
    Default strange problem 12f675
    Hello Everyone. I just ran across a very strange problem and wanted to know if anyone knows why. This header file for a 12F675 works perfectly. However if you put "HIGH GPIO.2" underneath "GPIO = %00000000" it causes GPIO.4 to go high. I didn't check if others were going high as I have a LED on GPIO.4. Why did this happen? Thank you.
    ANSEL = 0 'all inputs digital
    CMCON = 7 'comparators off
    DEFINE OSCCAL_1K 1 ' Set OSCCAL for 1K device
    @ DEVICE MCLR_OFF, INTRC_OSC_NOCLKOUT, WDT_ON, BOD_ON, PWRT_ON, PROTECT_ON
    TRISIO = %00000010 'GPIO.1 INPUT
    GPIO = %00000000 'ALL OUTPUTS LOW
    '******HIGH GPIO.2 'HERE IS THE PROBLEM. UNCOMMENT THIS LINE & GPIO.4 GOES HIGH!!!
    ONTIMER VAR BYTE 'VARIABLE FOR TIMER
    OFFTIMER VAR BYTE 'VARIABLE FOR OFF POTENTIOMETER
    TIMER VAR BYTE 'VARIABLE TO COMPARE OFF POTENTIOMETER
    Clear 'ALL VARIABLES = 0
    Pause 5000 'WAIT 5 SECONDS
    No problem here
    What happen if you remove the DEFINE OSCCAL_1K ?
    What happen if you insert a PAUSE 50 before HIGH GPIO.2?
  1. strange serout2 problem
    By KaanInal in forum mel PIC BASIC Pro
    Last Post: - 7th January 2010, 10:33
  2. PIC stop responding - Strange Problem!
    Last Post: - 31st August 2009, 15:06
  3. Strange I2C problem (and solution)
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2008, 20:14
  4. Strange problem with Serin/Serout on 16F628
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2008, 01:16
  5. 12f675 Serout Int_Osc problem
    Last Post: - 30th April 2007, 10:39
