New to coding - Please look at my code thanks!
Results 1 to 14 of 14
    Jul 2007
    Default New to coding - Please look at my code thanks!
    Just started a few days ago, PBPro Compiler gives me a whole list of syntax errors etc.. Please let me know if what is wrong it.
    [html]
    ' Set Internal Oscillator to 4MHz
    ' Pin 01 - V_DD - +5v
    ' Pin 08 - V_SS - GND
    ' GPIO.0 - GP0 - 07 - DIG - input for momentary button
    ' GPIO.1 - GP1 - 06 - DIG - output for op indicator LED
    ' GPIO.2 - GP2 - 05 - DIG - output to switch on sprayer
    ' GPIO.3 - GP3 - 04 - DIG - input to monitor fan op
    ' GPIO.4 - GP4 - 03 - DIG - NC
    ' GPIO.5 - GP5 - 02 - DIG - NC
    '---------- Options ------------------------------------------------------------
    define OSC $60 'Set oscillator (clk) to 4MHz
    ANSEL = %000000 'Analog/Digital ports
    INTCON = 'GPIO External interrupts
    GPIO = %000000 'Set High/Low GPIO.5 -> GPIO.0 (all low)
    TRISIO = %001001 'Set input/output GPIO.5 -> GPIO.0 (GP0 & 3 input)
    '---------- Constants & Symbols/Variables --------------------------------------
    M_BUT con GPIO.0 'Name bit 0 of GPIO to Momentary Button
    LED con GPIO.1 'Name bit 1 of GPIO to LED
    PUMP con GPIO.2 'Name bit 2 of GPIO to Pump
    FAN con GPIO.3 'Name bit 3 of GPIO to Fan
    symbol ON_OFF = 1
    '---------- Subroutines & Loops ------------------------------------------------
    PUMP_RUN: 'This is defined for the pump on/off
    symbol X0 = 0 'X0 is the variable used in LED_F loop for counting
    pump = 0 'Turn misting pump on
    LED_RUN: 'LED Flash loop begins here
    if X0 < 10 then
    gosub LED_F
    LED = 0 'Makes sure LED is off
    pump = 0 'Turns relay controlling the pump off
    return 'Returns to main code
    LED_F:
    LED 1 'Turns on the warning LED
    pause 500 'Pause 500mS (1/2 second) with LED on
    LED = 0 'Turns off warning LED
    pause 500 'Pause 500mS (1/2 second) with LED off
    X0 + 1 'This adds 1 to variable X0 each time it loops
    goto LED_RUN 'Returns to begining of LED Flash loop
    FAN_RUN:
    if FAN = 1 then 'If cooling fans are on then...
    gosub Pump_run 'Run pump sequence
    pause 15000 'Pause for 15 seconds, no point in saturating
    pause 5000 'Pause for 5 seconds
    goto fan_run 'Returns to beginning to see if fan is running
    '---------- Main Code ----------------------------------------------------------
    if M_BUT = 1 then 'If the button is pressed then...
    Pause 2000 'Wait 2 seconds before continuing
    if M_BUT = 1 then 'If button is still pressed
    gosub PUMP_RUN 'Then run the pump and flash LED
    if ON_OFF = 1 then 'If auto-spray is on...
    ON_OFF = 0 'Then turn it off
    else 'Otherwise...
    ON_OFF = 1 'Turn auto-spray on
    ENdif
    [/html]
    Only other question with this is, do I need to use an interrupt for the button if the fan trig has turned on the pump, and running the LED Flash loop?
    M_BUT VAR GPIO.0.....and so on for the rest of them
    Read the manual. Con only assigns a number to a name, not a pin to a variable.
    symbol ON_OFF = 1....SYMBOL not explicitly needed, unless you're using PicBasic compiler instead of PBP
    if X0 < 10 then
    gosub LED_F
    NO ENDIF HERE ---where's the ENDIF?
    ---That might be what you want it to do, but it's not going to do that
    X0 = X0 + 1
    Look at your code a little harder next time. You'll spot these errors a lot faster and easier if you've got the manual handy.
    Hi, and welcome here !
    Please, next time tell us which PIC # you're using
    I see some things wrong here
    define OSC $60
    should be 4,8 or whatever else crystal value you're using. Assuming you MAY use a 12F683 you will need to set the OSCCON register instead.
    4MHz is the default speed, you don't really need to tell it to the compiler.
    <hr>
    NEXT!
    INTCON      =
    it miss something here.. like a value
    use VAR instead of CON will solve the problem.
    ON_OFF VAR bit
    ON_OFF = 1
    X0 VAR BYTE
    X0= 0
          if X0 < 10 then
          gosub  LED_F
    LED_F:
      LED = 1                     'Turns on the warning LED
      X0 = X0 + 1                    'This adds 1 to variable X0 each time it loops
    It compile without error... not sure if it do what you need
    Jul 2007
    I appreciate it guys. Like I said, first time coding.
    I missed somethings since I did it at 2am last night = half asleep
    Anyhow yes, 12F683
    Will I have any problems with bouncing on the button?
    and I haven't found/read any good information on how to setup the INTCON or INTOSC on the chip.
    THANKS A LOT GUYS! only error I get now is the INTCON and that one I knew would show up.
    Really thanks a bunch.
    did you tried with the datasheet ? For the internal OSC, have a look for OSCCON register
    Ok, what do you need to do exactly? There's more than one way to skin a cat anyways....
    Jul 2007
    I am worried that the PIC will only be able to deal with one loop at a time, and if that is the case then...
    When fans come on it will be stuck for 10 seconds doing one thing when maybe the user wants to turn the system off.
    So if that is the case, then I may need to make use of interrupts.
    and I will look at the datasheet in a little while, racing in Forza 2 ATM, damn Ferrari is hard to drive with AI at hardest difficulty.
    could be worst if you had a Pagani Zonda on hand
    So now, YES interrupts would be handy INDEED.
    Jul 2007
    i hate those cars, the turn in on them is horrible! worse than a car like the impreza that was designed to have understeer issues!
    P.S. when you have understeer problems you have to purposely induce a drift/power slide to get the damn car to turn. I know I drive an Impreza in RL, a lot easier to get it to oversteer if you have the balls to go into a turn waaaay too fast, and punch the brakes to the thresh-hold and back waay off and it loosens the rear up (all while turning). But that helps with more money in the car than I actually paid for it 4 years ago.
    Anyhow, the osccon register,
    OSCCON = 0 110 0 1 1 1
    bit 7 = nothing, so 0 is used
    bit 6-4 = 4MHz
    bit 3 = device running from secondary clock (Internal osc)
    bit 2 = I want a stable high freq clock
    bit 1 = no idea, INTRC, made it stable I shouldn't be using this but what do I know... stable girlfirend is better than unstable so I picked stable
    bit 0 = internal osc is used because i dont want to waste space/money on ext osc.
    Jul 2007
    INTCON or Interrupt-on-Change IOCCON ?
    INTCON = 00 0 0 0 0 0 1
    bit 7-6 = 0 / unimplemented
    bit 5 = gpio.5
    bit 4 = gpio.4
    bit 3 = gpio.3
    bit 2 = gpio.2
    bit 1 = gpio.1
    bit 0 = gpio.0
    GPIO.0 = M_BUT so 1 = enable
    Jul 2007
    So does this look right;
    [html]
    define OSC 4 'Set oscillator (clk) to 4MHz
    OSCCON = %01100111 'Oscillator Settings
    INTCON = %00000001 'GPIO External interrupts
    [/html]
    Problem it is throwin some errors on it.
    no compilation error here...
    Jul 2007
    it is saying
    thinks they are symbols
    Quote Originally Posted by erice1984 View Post
    it is saying
    Doesn't look like you've got 12F683 selected in the drop down...
    Jul 2007
    ya got me, thanks.. I didn't realize that was important, thought it was only used for programming
    All I need to do is make use of interrupts and I think this thing is ready for a try
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Timer PIC16F57
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 09:14
