LANC code 12F675
Results 1 to 5 of 5
    Jul 2007
    Default LANC code 12F675
    I found this code some years ago and do not know its source. There was only a text descrption of the circuit. I don't understand what the xxxx_ACTIVE subroutines are pulsing GPIO.0 for. GPIO.3 and 5 are in/out and 2 is for an LED. Any ideas?
    DEVICE 12F675
    'WORKING STANDARD LANC CONTROL FOR 12F675 CHECKED 10/05/2004
    'THIS VERSION USE A BC107 AS OPEN COLLECTOR ON THE SIGNAL INPUT
    'AS OPPOSED TO TH 2N 2907 PNP TRANSISTOR WHICH HAD A PROBLEM THAT
    'THE VOLTAGE IS NOT PULLED TO GROUND BUT TO AROUND 0.8V WHEN LOW
    'THE SOFTWARE NO OUTPUT AND INVERTED DATA STREAM ALSO INVERTING THE STOP BIT AND
    'START BIT
    'WHICH COULD NOT BE DONE BY JUST SPECIFYING DATA INVERTED WHEN USING RSOUT
    SET_OSCCAL
    'OSCCAL=$60 ' PROGRAM WITH PROTECTION ON WATCHDOG OFF ,INTERNAL OSC,MCLR OFF,
    CMCON=7
    ADCON0=0
    ANSEL=0
    CONFIG WDT_OFF , PWRTE_ON ,MCLRE_OFF
    ALL_DIGITAL=TRUE
    DECLARE XTAL 4
    DECLARE RSIN_PIN GPIO.3
    DECLARE RSIN_MODE TRUE
    DECLARE SERIAL_BAUD 9600
    DECLARE RSIN_TIMEOUT 20000
    DECLARE RSOUT_PIN GPIO.5
    DECLARE RSOUT_MODE TRUE
    SYMBOL LED =GPIO.2
    DIM GAP,FBYTE0,FBYTE1,FBYTE2,FBYTE3,FBYTE4,FBYTE5,FBYT E6,FBYTE7,COMMAND,DO_AGAIN
    DIM REC_STATUS,FLIPFLOP,TRIGGER
    DIM GAPCOUNT AS WORD
    DIM OLD AS BYTE
    DIM FAULT_COUNTER AS WORD
    TRISIO=%011010
    start: INPUT GPIO.5
    FBYTE0=%00011000^$FF
    GOTO MAIN
    GAP_TIME: GAPCOUNT=0
    DO: IF GPIO.3 <>1 THEN GOTO GAP_TIME
    GAPCOUNT=GAPCOUNT+1
    IF GAPCOUNT <150 THEN GOTO DO
    COMMANDOUT: 'OUTPUT GPIO.5
    WHILE GPIO.3=1 :WEND
    'RSOUT FBYTE0
    OUTPUT GPIO.5
    SET GPIO.5 'START BIT
    DELAYUS 94 '11100111
    CLEAR GPIO.5 'FIRST LSB BIT
    DELAYUS 104 'BIT1
    DELAYUS 104 'BIT2
    DELAYUS 104 'BIT3
    SET GPIO.5
    DELAYUS 104 'BIT4
    DELAYUS 104 'BIT5
    CLEAR GPIO.5
    DELAYUS 104 'BIT6
    DELAYUS 104 'BIT7
    DELAYUS 104 'BIT8
    DELAYUS 104 'STOP BIT
    INPUT GPIO.5
    'RSOUT COMMAND
    OUTPUT GPIO.5
    SET GPIO.5
    DELAYUS 94 'STOP BIT
    IF COMMAND=$3A THEN
    CLEAR GPIO.5
    DELAYUS 104 'BIT1 LSB
    SET GPIO.5
    DELAYUS 104 'BIT2
    CLEAR GPIO.5
    DELAYUS 104 'BIT3
    SET GPIO.5
    DELAYUS 104 'BIT4
    DELAYUS 104 'BIT5
    DELAYUS 104 'BIT6
    CLEAR GPIO.5
    DELAYUS 104 'BIT7
    DELAYUS 104 'BIT8
    'RSOUT COMMAND
    CLEAR GPIO.5
    DELAYUS 104 'BIT2
    DELAYUS 104 'BIT3
    DELAYUS 104 'BIT4
    SET GPIO.5
    DELAYUS 104 'BIT5
    DELAYUS 104 'BIT6
    CLEAR GPIO.5
    DELAYUS 104 'BIT7
    DELAYUS 104 'BIT8
    INPUT GPIO.5
    FBYTE2=RSIN
    FBYTE3=RSIN
    FBYTE4=RSIN
    FBYTE5=RSIN
    FBYTE6=RSIN
    INTERPRET: LET FBYTE4=FBYTE4^$FF
    IF FBYTE4=OLD THEN GOTO DONE
    LET OLD=FBYTE4
    IF FBYTE4=$02 THEN GOSUB STOP_ACTIVE
    IF FBYTE4=$01 THEN GOSUB FAULT_ACTIVE
    IF FBYTE4=$04 THEN GOSUB RECORD_ACTIVE
    IF FBYTE4=$32 THEN GOSUB FAULT_ACTIVE
    IF FBYTE4=$62 THEN GOSUB FAULT_ACTIVE
    DONE: RETURN
    STOP_ACTIVE: REC_STATUS=0
    CLEAR GPIO.2 ' RECORDING IS ACTIVE LED
    SET GPIO.0 'PULSE1
    DELAYMS 500
    CLEAR GPIO.0
    DELAYMS 500
    SET GPIO.0 'PULSE2
    DELAYMS 500
    CLEAR GPIO.0
    DELAYMS 500
    SET GPIO.0 'PULSE3
    DELAYMS 500
    CLEAR GPIO.0
    FAULT_ACTIVE: FAULT_COUNTER=0
    SET GPIO.0 'PULSE1
    DELAYMS 100
    CLEAR GPIO.0
    DELAYMS 100
    SET GPIO.0 'PULSE2
    DELAYMS 100
    CLEAR GPIO.0
    DELAYMS 100
    SET GPIO.0 'PULSE3
    DELAYMS 100
    CLEAR GPIO.0
    DELAYMS 100
    SET GPIO.0 'PULSE4
    DELAYMS 100
    CLEAR GPIO.0
    DELAYMS 100
    SET GPIO.0 'PULSE5
    DELAYMS 100
    CLEAR GPIO.0
    RECORD_ACTIVE: REC_STATUS=1
    SET GPIO.0
    SET GPIO.2 ' RECORDING IS ACTIVE LED
    DELAYMS 3000
    CLEAR GPIO.0
    MONITOR: WHILE GPIO.1=0
    TRIGGER=0
    WEND
    'TRIGGER=GPIO.1
    IF TRIGGER=1 THEN GOTO DONEMON
    IF TRIGGER =0 THEN GOSUB INVRECSTATUS
    DONEMON: RETURN
    INVRECSTATUS: IF REC_STATUS =1 THEN FLIPFLOP=0
    IF REC_STATUS =0 THEN FLIPFLOP=1
    REC_STATUS=FLIPFLOP
    LOAD_COMMAND: IF REC_STATUS=0 THEN COMMAND=$30'^$FF 'NEW COMMAND = STOP
    IF REC_STATUS=1 THEN COMMAND=$3A'^$FF 'NEW COMMAND = REC
    MAIN: GAP=0 : GAPCOUNT=0 : FBYTE1=0 : FBYTE2=0 : FBYTE3=0 : FBYTE4=0
    FBYTE5=0 : FBYTE6=0 : FBYTE7=0 : DO_AGAIN=0
    TRIGGER=0 : FLIPFLOP=0 : FAULT_COUNTER=0 : gpio.0=0 : gpio.2=0
    COMMAND=$00^$FF
    'SET GPIO.5
    RERUN: DO_AGAIN=0
    AGAIN3: GAPCOUNT=0
    GOSUB GAP_TIME
    DO_AGAIN =DO_AGAIN+1
    IF DO_AGAIN<=5 THEN GOTO AGAIN3
    GOSUB INTERPRET
    'DELAYMS 1000 ' WAIT WHILE TRIGGER MIGHT STILL BE ACTIVATED
    GOSUB MONITOR
    IF TRIGGER=0 THEN GOSUB LOAD_COMMAND
    'CHANGED ON 9/9/2003 'IF TRIGGER=1 THEN GOSUB LOAD_COMMAND
    TRIGGER=1
    GOTO RERUN
    That's PDS Proton... on a PBP forum
    SET GPIO.x will translate to GPIO.x = 1 or HIGH GPIO.x (ASM BSF)
    Clear GPIO.x, will translate GPIO.x=0 (ASM BCF)
    Rsout = DEBUG
    DelayMS = PAUSE
    DelayUs = PAUSEUS
    ALL_DIGITAL = should be something like ANSEL=0 AND CMCON = 7
    Now just translate it to PBP, build the circuit,. and you're half done
    Jul 2007
    No wonder I could not find it in a PicBasic Pro search! I just dug out my v2.45 and had not even tried to compile it. Still not sure what the toggling of GPIO.0 is about.
    Rsout = DEBUG
    DelayMS = PAUSE
    DelayUs = PAUSEUS
    New England
    Quote Originally Posted by MikeDD View Post
    Well... when I was writing code for my LANC control a while back, I used some blinking LED's as very basic debugging indicators - it looks like this code does the same.
    After various commands, etc, the code does some blinky LED stuff in order for the PIC to let the user know that everything is working OK. Also looks like some error status might be reported too.
    Arch
    "Data sheets? I ain't got no data sheets. I don't need no data sheets. I don't have to read any stinking data sheets!"
    Jul 2007
    Post
    As this project may be interesting to me, I attempted to convert the proton version...
    it ended with something like that, but I haven't got time to test it yet
    (*debugin* part, schematics, and some other loops aren't quite clear for me yet....)
    '** LANC CONTROL FOR *12F683 modified, BUT NOT TESTED at all yet
    '** THIS VERSION USE A BC107 AS OPEN COLLECTOR ON THE SIGNAL INPUT
    '** AS OPPOSED TO TH 2N 2907 PNP TRANSISTOR WHICH HAD A PROBLEM THAT
    '** THE VOLTAGE IS NOT PULLED TO GROUND BUT TO AROUND 0.8V WHEN LOW
    '** THE SOFTWARE NO OUTPUT AND INVERTED DATA STREAM ALSO INVERTING
    '** THE STOP BIT AND START BIT WHICH COULD NOT BE DONE BY JUST
    '** SPECIFYING DATA INVERTED WHEN USING RSOUT
    ;** DEVICE 12F683
    ;** //Check INC file setup!!!!
    ;set in INC file => device pic12F683, intrc_osc_noclkout, wdt_off, mclr_on, protect_off ;
    ;;;Include "modedefs.bas" si jamais on utilise des routines SERIN/SEROUT
    ANSEL = %00000000 ' No Analog input, set all digital
    CMCON0 = %00000111 ' turn comparators off 07H
    TRISIO = %111010 ' inputs port1,3,4 outputs 0
    GPIO = %000000 ' outputs low << very important it seems!!
    OSCCON = %01100000 ' Internal 4MHz osc set speed
    INTCON = 0 'Do not use PBP interrupts
    define OSC 4 '4mhz clock internal
    'Output on GPIO.5
    DEFINE DEBUG_REG GPIO
    DEFINE DEBUG_BIT 5 ' GPIO.5
    DEFINE DEBUG_BAUD 9600 ' 2400 bps
    DEFINE DEBUG_MODE 0 ' 1 = inverted, 0 = true
    'Input on GPIO.4
    DEFINE DEBUGIN_REG GPIO ' Set Debugin pin port
    DEFINE DEBUGIN_BIT 4 ' Set Debugin pin bit
    'Other unspecified params are taken from DEBUG settings
    ;;DECLARE RSIN_PIN GPIO.3 >> switched for GPIO.4
    ;;DECLARE RSIN_MODE TRUE
    ;;DECLARE SERIAL_BAUD 9600
    ;;DECLARE RSIN_TIMEOUT 20000
    ;;DECLARE RSOUT_PIN GPIO.5
    ;;DECLARE RSOUT_MODE TRUE
    ;;;;;Translation to test fron Proton code, si marche pas essaye Array[]??
    FBYTE0 VAR BYTE
    FBYTE1 VAR BYTE
    FBYTE2 VAR BYTE
    FBYTE3 VAR BYTE
    FBYTE4 VAR BYTE
    FBYTE5 VAR BYTE
    FBYTE6 VAR BYTE
    FBYTE7 VAR BYTE
    COMMAND VAR BYTE
    OLD VAR BYTE
    flshLight VAR BYTE
    DO_AGAIN VAR BIT
    REC_STATUS VAR BIT
    TRIGGER VAR BIT
    GAPCOUNT VAR WORD
    LED_act VAR GPIO.2 'Activity LED
    start:
    INPUT GPIO.5
    FBYTE0=%00011000^$FF ; $FF = %11111111
    GOTO MAIN
    GAP_TIME:
    GAPCOUNT=0
    DO:
    IF GPIO.4 <>1 THEN GOTO GAP_TIME
    GAPCOUNT=GAPCOUNT+1
    COMMANDOUT:
    'OUTPUT GPIO.5 ;; Delete?
    WHILE GPIO.3=1 :WEND ;; Check Syntax.
    'RSOUT **FBYTE0**
    OUTPUT GPIO.5 ;Writing on the LANC line..
    GPIO.5 = 1 'START BIT
    PAUSEUS 94 '11100111 #E7h?????? inverted >> %00011000 = #18h would make sense
    GPIO.5 = 0 'FIRST LSB BIT
    PAUSEUS 104 'BIT1
    PAUSEUS 104 'BIT2
    PAUSEUS 104 'BIT3
    GPIO.5 = 1
    PAUSEUS 104 'BIT4
    PAUSEUS 104 'BIT5
    GPIO.5 = 0
    PAUSEUS 104 'BIT6
    PAUSEUS 104 'BIT7
    PAUSEUS 104 'BIT8
    PAUSEUS 104 'STOP BIT
    INPUT GPIO.5 ;Listening on the LANC line..
    WHILE GPIO.4=1 :WEND ; ??Waiting for Start bit??
    'RSOUT COMMAND
    GPIO.5 = 1
    PAUSEUS 94 'STOP BIT
    IF COMMAND=$3A THEN ; #3Ah <=> #58d <=> %00111010 (??send inverted as %11000101)
    GPIO.5 = 0
    PAUSEUS 104 'BIT1 LSB
    GPIO.5 = 1
    PAUSEUS 104 'BIT2
    GPIO.5 = 0
    PAUSEUS 104 'BIT3
    GPIO.5 = 1
    PAUSEUS 104 'BIT4
    PAUSEUS 104 'BIT5
    PAUSEUS 104 'BIT6
    GPIO.5 = 0
    PAUSEUS 104 'BIT7
    PAUSEUS 104 'BIT8
    'RSOUT COMMAND; $30 <=> #30h <=> #48d <=> %00110000 (??send inv as %11001111)
    GPIO.5 = 0
    PAUSEUS 104 'BIT2
    PAUSEUS 104 'BIT3
    PAUSEUS 104 'BIT4
    GPIO.5 = 1
    PAUSEUS 104 'BIT5
    PAUSEUS 104 'BIT6
    GPIO.5 = 0
    PAUSEUS 104 'BIT7
    PAUSEUS 104 'BIT8
    ;;FBYTE2=RSIN ;;replaced proton code
    ;;FBYTE3=RSIN ;;FBYTE4=RSIN ;;FBYTE5=RSIN ;;FBYTE6=RSIN
    DEBUGIN [FBYTE2]
    DEBUGIN [FBYTE3]
    DEBUGIN [FBYTE4]
    DEBUGIN [FBYTE5]
    DEBUGIN [FBYTE6]
    RETURN ;----------------------------------------------
    INTERPRET:
    FBYTE4=FBYTE4^$FF ;; just an Inverter?
    OLD=FBYTE4
    ;;; should invert all BYTE before sending!?
    ;;; DEBUG 1, "LANC:",FBYTE0,FBYTE1,FBYTE2,FBYTE3,FBYTE4,FBYTE5, FBYTE6,FBYTE7,">"
    DONE:
    STOP_ACTIVE:
    REC_STATUS=0
    GPIO.2 = 0 ' RECORDING IS ACTIVE LED
    for flshLight=1 to 5
    GPIO.0 = 1 'PULSE LED/Port
    PAUSE 500
    GPIO.0 = 0
    PAUSE 500
    next flshLight
    FAULT_ACTIVE:
    PAUSE 100
    GPIO.0 = 0
    PAUSE 100
    next flshLight
    RECORD_ACTIVE:
    REC_STATUS=1
    GPIO.0 = 1
    GPIO.2 = 1 ' RECORDING IS ACTIVE LED
    PAUSE 3000
    GPIO.0 = 0
    MONITOR:
    WHILE GPIO.1=0 'Input switch!
    TRIGGER=0
    WEND
    IF TRIGGER = 1 THEN GOTO DONEMON
    IF TRIGGER = 0 THEN GOSUB INVRECSTATUS
    DONEMON:
    INVRECSTATUS:
    REC_STATUS = REC_STATUS^1 ;;Flipflop
    LOAD_COMMAND:
    IF REC_STATUS=1 THEN COMMAND=$3A'^$FF 'NEW COMMAND = REC RETURN
    MAIN:
    GAPCOUNT=0
    FBYTE1=0
    FBYTE2=0
    FBYTE3=0
    FBYTE4=0
    FBYTE5=0
    FBYTE6=0
    FBYTE7=0
    DO_AGAIN=0
    TRIGGER=0
    gpio.0=0
    gpio.2=0
    COMMAND=$00^$FF
    RERUN:
    DO_AGAIN=0
    AGAIN3:
    GAPCOUNT=0
    GOSUB GAP_TIME
    'Resend data at least 5 times (lanc needs at least 3 valid command to exe.)
    GOSUB INTERPRET
    'PAUSE 1000 ' WAIT WHILE TRIGGER MIGHT STILL BE ACTIVATED
    GOSUB MONITOR
    TRIGGER=1
    GOTO RERUN
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. Loop with two motor and 2 sensors
  3. Making Program Code Space your playground...
  4. 12F675 code sample
    By marad73 in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2006, 14:53
  5. 12F675 Code Help
    By papa-smurf in forum mel PIC BASIC Pro
    Last Post: - 9th August 2004, 16:51
