Ttl - Rs232
Results 1 to 4 of 4
Thread: Ttl - Rs232
    Jul 2006
    Default Ttl - Rs232
    Hello All
    In my programm i not use the MAX232 inverter for serial communication to the PC, i use a 1k for tx and 22k resistor for rx Pic pin and the code like this
    bmode con 16780'
    ''''serin2' 16780 = 2400 inverted (without max232)
    instruction like this
    SERIN2 dinp,bmode,3000,main,[wait ("C"),HEX2 esp0,HEX2 esp1]
    now i need to connect my board to other board from a customer that communicate serial with TTL level
    My question is, must i change anything in my code to communicate in TTL level?
    Thanks for help
    Kind regards
    Pedro
    Dec 2005
    You are using TTL levels. You might have to change polarity. RS232 is usually inverted but the other board may be non-inverted.
    Jul 2006
    Hello
    The next questions is:
    Must i remove the 1k and 22k resistors from the circuit, i mean direct connecting the two processors?
    regards
    Pedro
    Dec 2005
    Sorry - I didn't see this earlier.
    The resistors are there to limit the current sourced or sunk by the PIC pins to a safe level. Assuming 5V logic, the 1K resistor limits the current to 5/1000=5mA. RS232 levels can be as high as 25V so the 22K resistor limits that current to 25/22000=~1mA. You can leave them as they are or you can replace the 22K with 1K. If there's any chance you'll connect it to RS232 levels, keeping the 22K is safest.
    Check the PIC datasheet to see the maximum current limits for each pin.
  1. Universal remote and Rs232
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 7th February 2010, 18:55
  2. UART vs software RS232
    Last Post: - 5th September 2008, 19:27
  3. RS232 into 2 PC ports
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 30th August 2008, 14:33
  4. Software RS232 and wireless modules
    Last Post: - 17th August 2008, 06:27
  5. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
