Stop the pic working
Results 1 to 14 of 14
    Jul 2007
    Default Stop the pic working
    How to stop the pic working when 1 input goes high? And how to make it resume when the same imput goes low? Please help me...
    Apr 2006
    New Hampshire USA
    Post Stop and Go....
    Hi sgufa,
    Quote Originally Posted by sgufa View Post
    You could try the sleep command. Don’t forget the watchdog timer, make sure it is turned on.
    Wake up little PIC!
    http://www.picbasic.co.uk/forum/showthread.php?t=6377
    Permanent sleep
    http://www.picbasic.co.uk/forum/showthread.php?t=3128
    Try searching the forum for sleep.
    Hope that helps,
    -Adam-
    You've not specified the reasons why the PIC should be stopped (or indeed your definition of 'Stop', or how quickly it should happen, or the state of the PIC when it is stopped), so to experiment, why not simply start with...
    	LED var PortB.1
    	StopPin var PortB.0
    	TRISB=%00000001
    Loop:	Toggle LED
    	Pause 500
    	While StopPin=1:Wend
    	Goto Loop
    Jul 2007
    many thanks melanie but i've just did the same. In that way the pic is always ON. I'd want to put the pic in low power mode when the input goes high and then, when the input returns low, wake up the pic in order to resume his work
    @ SLEEP
    will do the job.
    Now depending the PIC you're using, you need to be check which i/o can wake the PIC.
    Jul 2007
    i'm using 16f628a
    can you make me an example for the sleep?
    i'm using 16f628a
    @ SLEEP
    And judging from your other few posts...are you using PicBasicPro or Proton Basic?
    Jul 2007
    I imagined that
    but i mean an example with the routine for sleep and awake on input HI/lo
    P.S. I use proton+ picbasic v3
    Oct 2003
    holland
    Then you are in the wrong forum.
    http://www.picbasic.org/forum/
    is then a better forum for you.
    Jul 2007
    assuming that Basic is always Basic if anyone is so gentle in showing me how to make my goal, i think I'm able to "port" the code from picbasicpro to proton...
    I think Melanie's example in post #3 should do the trick.
    Is there something different that you need?
    Added: Oops, looking for low power mode. Re-thinking.
    Apr 2006
    New Hampshire USA
    Default searching for sleep
    Hi sgufa,
    to search the PICBASIC forum, try pasting this whole line into Google:
    nap OR sleep 16f628a OR PIC16f628a site:http://www.picbasic.co.uk/forum/
    or
    to search the Proton forum, try pasting this whole line into Google:
    low power 16f628a OR PIC16f628a site:http://www.picbasic.org/forum/
    see also
    Darrel Taylor’s great post:
    A better Search tool for the Forum
    http://www.picbasic.co.uk/forum/show...11&postcount=1
    -Adam-
    Ok, this would be for PicBasic Pro. Tested on an 877, but it should still work with a 628.
    How you do it in Proton, I haven't got a clue.
    @ DEVICE WDT_OFF   ; Disable Watch-Dog timer
    LED     VAR PORTB.1
    StopPin VAR PORTB.0
    INTEDG  VAR OPTION_REG.6   ; 0 = falling edge, 1 = rising
    INTE    VAR INTCON.4       ; External interrupt Enable bit
    INTF    VAR INTCON.1       ; External interrupt Flag
    Delay   VAR WORD
    INPUT  StopPin             ; Is already default, but just to make sure
    INTEDG = 0                 ; Interrupt on falling edge
    INTE = 1                   ; Enable External Interrupts
        Toggle LED
        For Delay = 1 to 500
            PAUSE 1
            IF StopPin = 1 THEN
               LOW  LED            ; Turn OFF anything that will draw current
               INTF = 0            ; Clear the Interrupt Flag
               @ SLEEP             ; enter Low Power mode
               GOTO MAIN
        NEXT Delay
    Goto Main
    HTH,
    Jul 2007
    Smile
    many thanks for the suggestions. I'll give it a try...
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. PIC powered by capacitor for 0,5 second
    Last Post: - 25th August 2007, 09:23
  3. VB sending serial data to PIC
    By Tissy in forum Serial
    Last Post: - 8th March 2006, 18:31
  4. Serial Pic to Pic using HSER
  5. 256 Pics Communicate to 1 Master Pic
    By mazlan in forum mel PIC BASIC Pro
    Last Post: - 15th July 2004, 13:11
