New to coding - Please look at my code thanks!
Results 1 to 14 of 14
    could be worst if you had a Pagani Zonda on hand
    So now, YES interrupts would be handy INDEED.
    Jul 2007
    i hate those cars, the turn in on them is horrible! worse than a car like the impreza that was designed to have understeer issues!
    P.S. when you have understeer problems you have to purposely induce a drift/power slide to get the damn car to turn. I know I drive an Impreza in RL, a lot easier to get it to oversteer if you have the balls to go into a turn waaaay too fast, and punch the brakes to the thresh-hold and back waay off and it loosens the rear up (all while turning). But that helps with more money in the car than I actually paid for it 4 years ago.
    Anyhow, the osccon register,
    OSCCON = 0 110 0 1 1 1
    bit 7 = nothing, so 0 is used
    bit 6-4 = 4MHz
    bit 3 = device running from secondary clock (Internal osc)
    bit 2 = I want a stable high freq clock
    bit 1 = no idea, INTRC, made it stable I shouldn't be using this but what do I know... stable girlfirend is better than unstable so I picked stable
    bit 0 = internal osc is used because i dont want to waste space/money on ext osc.
    Jul 2007
    INTCON or Interrupt-on-Change IOCCON ?
    INTCON = 00 0 0 0 0 0 1
    bit 7-6 = 0 / unimplemented
    bit 5 = gpio.5
    bit 4 = gpio.4
    bit 3 = gpio.3
    bit 2 = gpio.2
    bit 1 = gpio.1
    bit 0 = gpio.0
    GPIO.0 = M_BUT so 1 = enable
    Jul 2007
    So does this look right;
    [html]
    '---------- Options ------------------------------------------------------------
    define OSC 4 'Set oscillator (clk) to 4MHz
    OSCCON = %01100111 'Oscillator Settings
    ANSEL = %000000 'Analog/Digital ports
    INTCON = %00000001 'GPIO External interrupts
    GPIO = %000000 'Set High/Low GPIO.5 -> GPIO.0 (all low)
    TRISIO = %001001 'Set input/output GPIO.5 -> GPIO.0 (GP0 & 3 input)
    [/html]
    Problem it is throwin some errors on it.
    no compilation error here...
    Jul 2007
    it is saying
    thinks they are symbols
    Quote Originally Posted by erice1984 View Post
    it is saying
    Doesn't look like you've got 12F683 selected in the drop down...
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Timer PIC16F57
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 09:14
