6 Buttons
Results 1 to 4 of 4
Thread: 6 Buttons
    Jun 2007
    Default 6 Buttons
    I need to complile a program with 6 buttons lets say it's connected from portb0-5. When the user press button 1345 the code must send out serial 134&5. I'm still new with picbasic and I just don't know where to start?
    Any help
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Johansch View Post
    Any help
    Start with hooking up some buttons and getting an LED to respond to a button press...
    a bit far of what you need to do... but you may find some tricks in it...
    Combination Gate Access
    http://www.picbasic.co.uk/forum/show...=gate+operator
    Enjoy!
    Jun 2007
    Thanks for that many info, but I think that is way over my head I'm only in my second week in picbasic and also doing it part time.
    The code I started is like this for 4 buttons
    Include "16f84a.inc"
    Key1 var byte
    Key2 var byte
    Key3 var byte
    Key4 var byte
    Start: if portb.0 = 1 then key1 = 0
    if portb.1 = 1 then key2 = 1
    if portb.2 = 1 then key3 = 2
    if portb.3 = 1 then key4 = 3
    if porta.0 = 1 then Sout
    goto start
    Sout:
    high 7
    serout porta.4,N2400,[#key1,#key2,#key3,#key4]
    clear
    goto start
    I did use the button function and I get the same result as the one above, the problem is that the code do send serout 0123 format, yes I know I set that up that way for serout, but I need to send it out in the sequence the buttons was pressed say for example 0231 or lets say there was a button that was pressed twice "0122", this is where I don’t know how to set that up
    Thanks for all the help !
  1. 6 MHz Osc and PauseUSL errors
    By vk2tds in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 06:04
  2. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 20:03
  3. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  4. 6 random numbers limiting to 49 ?????
    By SuB-ZeRo in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 00:27
  5. '877 and Visual Basic 6
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 4th March 2004, 03:31
