Hi Abdykerim,
Error #1
There's 2 DoUSBIn, AND 2 DoUSBOute label, They are located at the bottom of your program...
Error #2,3,4,5,6,7,8,9,A,B,... Ok Ok
once you have commented the default config fuses in the 18F2455.INC file located PBP folder
... nothing else wrong happen IF AND ONLY IF YOU HAVE SELECTED THE RIGHT PIC IN THE DROP MENU AS WELL ...Code:;**************************************************************** ;* 18F2455.INC * ;* * ;* By : Leonard Zerman, Jeff Schmoyer * ;* Notice : Copyright (c) 2006 microEngineering Labs, Inc. * ;* All Rights Reserved * ;* Date : 06/05/06 * ;* Version : 2.47 * ;* Notes : * ;**************************************************************** NOLIST ifdef PM_USED LIST "Error: PM does not support this device. Use MPASM." NOLIST else LIST LIST p = 18F2455, r = dec, w = -311, w = -230, f = inhx32 INCLUDE "P18F2455.INC" ; MPASM Header ; __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L ; __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H ; __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H ; __CONFIG _CONFIG3H, _PBADEN_OFF_3H ; __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L NOLIST endif LIST EEPROM_START EQU 0F00000h BLOCK_SIZE EQU 32
