Hello to all,
I have a little problem on the 12F683. I want to get the pin GPIO.0 to switch from a LOW state (GND) to a High impedence state (High Z) and while in High Z take an anolog to digital conversion at GPIO.4.
The problem with the current circuit and Code that i have (attached is a schematic and sample code) is that while in in the LOW State the A/D will be normal and read normal voltage. However, in the HIGH Z state the PIN GPIO.4 (or AN3) will jump to a HIGH state (i.e to VDD).
Does anyone have any suggestions on how I can go about achieving this task? Maybe another way of switching from High Z to Gnd? Any help would be greatly appreciated.
Sammple Code:
'Define ADCIN parameters
Define ADC_BITS 10 ' Set number of bits in result
Define OSC 4 'define oscilator
Volt VAR WORD
TRISIO = %010000 'Set GPIO.0 as OUTPUT
LOW GPIO.0 'GND STATE
Pause 5000
TRISIO = %010001 'Set GPIO.0 as input (HIGH Z State)
pause 4000
ADCIN 3, Volt
if Volt >= 970 then loop
loop:
Schematic Attached:
Thank You All!
