Too many error !!
Results 1 to 3 of 3
    Jun 2007
    Default LED blinking ( again )
    I just got a 18F4431 from a friend.
    I tried to make led blink, with following code , but the only LED that turn on/off is the LED on RB0, why ?
    OSCCON = $60 ' Internal oscillator frequency 4 Mhz
    TRISA = %11111111 ' Set PORTA to all input
    TRISB = %00000000 ' Set PORTB to all output
    TRISC = %00000000 ' Set PORTC to all input
    TRISD = %00000000 ' Set PORTD to all output
    TRISE = %00000000 ' Set PORTE to all output
    ANSEL0= %00000000 ' Analog channel AN0-AN7 off
    ANSEL1= %00000000 ' Analog channel AN8 off
    PORTA = 0
    PORTB = 0
    PORTC = 0
    PORTD = 0
    PORTE = 0
    CLear
    high PORTB
    LOW PORTB
    HIGH PORTC
    LOW PORTC
    high PORTD
    low PORTD
    high PORTE
    LOW PORTE
    HIGH & LOW work with a "pin". Not a whole port. Try PORTB = %01010101 or
    some other 8-bit value to write to all 8-bits of a port at once.
    If using HIGH or LOW, then use a port 'bit' like HIGH PORTB.0, PORTB.1, etc.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2007
    Thank you Bruce,
    Yes, now it works
    I am a beginner with PBP,and I learn fast by making mistakes
    Now I will try to put some character on LCD
  1. Loop with two motor and 2 sensors
  2. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  3. pbp245 compliation error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2006, 06:59
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 10:47
