How to use Arrays Using Pic Basic Pro(need help)
Results 1 to 27 of 27
    MrSafe's Avatar
    MrSafe Guest
    I finally got the arrays to work correctly thank you very much.
    However now I am in a new hole. When I try to transmit the array using the command
    SEROUT2 PORTD.0, T1200, [STR htxt\StrLen,13,10]
    it will not send any data out. I found out the 13,10 in the program command is related to the hyper terminal in the pc from what I understand. so I modified the program command to
    SEROUT2 PORTD.0, T1200, [STR htxt\StrLen]
    I am using a TX module that transmits any data that is transmitted to it serially it sends out wirelessly and the RX unit then serially transmit data to pic as you can see from the command I am using PORT D pin Zero at baud rate 1200 however I am confused as to why it is not receiving any of the data do I have to change anything on the receiving end to make it work? I have included both my transmitting and my receiving codes.
  1. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 06:09
  2. Loop with two motor and 2 sensors
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 18:05
  4. vb6 to pic basic
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 19th December 2005, 01:56
  5. The Ultimate PIC Basic
    By picnaut in forum PBP Wish List
    Last Post: - 9th November 2004, 22:10
