How to use Arrays Using Pic Basic Pro(need help)
Results 1 to 27 of 27
    MrSafe's Avatar
    MrSafe Guest
    I still can not get the arrays to work. Look at my program to see what I am doing wrong I haven't tried the other suggestions yet but I will get started on those as soon as i figure out the arrays.
    MrSafe's Avatar
    MrSafe Guest
    In the program when i do
    lcdout #key it shoots out the key correctly on the lcd however
    when i use
    htxt(x) = #key
    it says bad expression when i try to compile
    also when i use
    htxt(x) = key
    it works fine however it displays a blank spot on the lcd
    Quote Originally Posted by MrSafe View Post
    when i use
    htxt(x) = #key
    also when i use
    htxt(x) = key
    htxt(x) = key ------>>>>> lookup key , [ "0123456789ABCDEF" ] , htxt[x]
    ^get rid of^---------------^^^^^^ replace with ^^^^^^^^^^^
    Your turn to figure out why assigning the variable 'key' to htxt(x) and trying to get the LCD to display what is effectively variable 'key' doesn't work.
    What is the ASCII character equivalent to 'key', if 'key' = 1? if 'key' = 2? if 'key' = 65?
    MrSafe's Avatar
    MrSafe Guest
    i see ill try thank you for the reply. If you don't mind could you give me an example of that a very simple version of it that I could run with. Im sorry for being so ignorant but arrays is brand spanking new to me.
    I can do that quite effectively ahaha its this damn blasted arrays thats slowing me down I have entire codes already done for that portion its just that I want to be able to loop the message over and over but I need arrays to do that and the message is not predetermined it will be different depending on the user.
    I just did...
    MrSafe's Avatar
    MrSafe Guest
    thank you it didn't appear for me
    MrSafe's Avatar
    MrSafe Guest
    The code below will compile all I did different from the code on the bottom is change the htxt[x] to x
    alpha1:
    gosub getkey
    LOOKUP key,[" ABCDEFGHIJ"],x
    htxt[x] = htxt[x] + 1
    alpha2:
    gosub getkey
    LOOKUP key,[" KLMNOPQRST"],htxt[X]
    The code above will not compile the compiler gives me the fallowing error
    "output parameter must be a variable"
  1. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 07:09
  2. Loop with two motor and 2 sensors
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  4. vb6 to pic basic
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 19th December 2005, 02:56
  5. The Ultimate PIC Basic
    By picnaut in forum PBP Wish List
    Last Post: - 9th November 2004, 23:10
