Composite USB Devices
Results 1 to 12 of 12
    Well that wouldn't make much sense.
    You can only have 1 master on a USB bus.
    So there's nothing else to access the slave part of your master/slave composite.
    Unless it's going to access itself.
    I've got this wireless hard drive with 2 USB ports...
    One USB port is for plugging in a 'thumbdrive', it copies the contents onto the local drive (Host mode).
    The other USB port is for plugging it into a PC, and making the box into an external drive (Slave mode).
    Obviously, you can't do both at once (plug in a 'thumbdrive' and access it thru the wireless hard drive, like there's 2 drives). I suppose, in theory, if the firmware was written correctly, the thing could access itself, somehow, I guess. But that would almost need 2 seperate USB controllers.
    Your drive has it's own Host controller.
    But you can't connect that to the main USB bus. Only external Slave devices.
    Anyhow, the original question from Kamikaze47 was about composite USB devices, such as shown in microchip's TB057. Although they call it "Combination devices".
    http://www.microchip.com/stellent/id...pnote=en011986
    Which is possible with PBP, but not directly supported.
    Yes, true, and that's what I thought was meant by 'composite USB', able to Host and Slave in the same box, but not at the same time.
    And yes, I can connect the box's internal hard drive to the PC thru the USB (thumbdrive port is dead, hard drive is slave)...and I can connect the thumbdrive to the PC thru the USB connections (hard drive port must act as a signal pass thru to the thumbdrive port or something, not sure)...and I can connect the thumbdrive to the hard drive by plugging it in (the PC port is dead, hard drive is master, thumbdrive port is slave).
    I just can't do any combination of any of the three at any one time.
    Jan 2006
    Toronto
    I think he still doesn't understand what a composite device is. Composite devices are slave only but are multiple slaves, for example, an HID mouse and keyboard in the same device like the USB to PS/2 converters or even maybe 2 PS/2 ports, a joystick port and a serial port in same device.
    Quote Originally Posted by PJALM View Post
    You're right...
    I don't have a clue about the difference between master, slave, and composite devices...
    Jan 2006
    Toronto
    Sorry didn't mean no disrespect, just trying to help
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  3. USB devices
    By MKtiger in forum USB
    Last Post: - 2nd November 2008, 11:23
  4. Two USB devices with same software, easyHID
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 31st October 2007, 07:19
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
