Lcdout question.
Results 1 to 5 of 5
    assuming you're using a 4MHZ crystal, it shouldn't be that bad, Higher than 4MHz... you'll need to use the according DEFINE and configuration fuses.
    Assuming you have a PAUSE 500-2000 at the top of your program, you could still tweak it a little bit and change the value of those DEFINES bellow
    DEFINE LCD_COMMANDUS 2000 ' Command delay time in us
    DEFINE LCD_DATAUS 50      ' Data delay time in us
    HTH
    May 2007
    Default It's working!!
    It's working. I was making two mistakes. I had the contrast pin three go to a voltage divider. and I was unpluging the lcd and pluging it back in. After I hard wired the contrast pin to gnd, it worked great.
    Here is the code I used. You will notice there are some commented stuff that isnt useful. But this works great with the schematic in the book. Thanks for all of your help.
    Steve Matson
    ' PICBASIC PRO program to display "Hello World" on LCD
    ' Define LOADER_USED to allow use of the boot loader.
    ' This will not affect normal program operation.
    Define LOADER_USED 1
    Define LCD_DREG PORTA 'Define LCD_DREG PORTA 'Define LCD_DREG PORTD
    Define LCD_DBIT 0 'Define LCD_DBIT 0 'Define LCD_DBIT 4
    Define LCD_RSREG PORTA 'Define LCD_RSREG PORTA 'Define LCD_RSREG PORTE
    Define LCD_RSBIT 4 'Define LCD_RSBIT 4 'Define LCD_RSBIT 0
    Define LCD_EREG PORTB 'Define LCD_EREG PORTB 'Define LCD_EREG PORTE
    Define LCD_EBIT 3 'Define LCD_EBIT 3 'Define LCD_EBIT 1
    ' ADCON1 = 7 ' Set PORTA and PORTE to digital
    Low PORTA.2 ' LCD R/W line low (W) 'WAS AN E
    Pause 100 ' Wait for LCD to start up
    loop: Lcdout $fe, 1 ' Clear screen
    Pause 500 ' Wait .5 second
    High PORTB.4
    Lcdout "Hello" ' Display "Hello"
    low PORTB.4
    Lcdout $fe, $c0, "World" ' Move to line 2 and display "World"
    Goto loop ' Do it forever
    Your initial Pause 100 could stand to be Pause 1000 or sometimes 2000.
    The 100 might work with this particular brand of LCD, but generally, most LCDs like a second or two for startup. Might save you some hassle in the future.
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 08:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
