INterfacing RTL8019As by PICbasic Pro
Results 1 to 5 of 5
    Jan 2007
    Question INterfacing RTL8019As by PICbasic Pro
    Hi Guys, Does any one know or have a sample code controlling RTL8019AS
    using PicBasic pro "pbp"? Thank you very much for your help
    Quote Originally Posted by naidab View Post
    Which mode are you planning on using the '8019 in?
    Dec 2005
    I haven't seen any PBP code but there is some BASCOM-AVR code for EDTP's Packet Whacker (RTL8019AS based) at http://members.home.nl/bzijlstra/sof...ples/basex.htm which you might be able to port to PBP.
    If you are not locked in to the RTL8019AS you might want to follow the PIC18F67J60 thread in this forum. I think it will prove more fruitful for PBP users.
    Jan 2007
    I was Planning to Interface P16f877 to RTl8019AS , using pbp picbasic pro compiler and coding in PBP , do you have any Idea of it? thanks
    Jan 2007
    Question
    Based on other forums, UDP mode is mostly possible, but any mode will do
    as long I can hook up PIC to LAN so that I can NETWORK all PIC's any sample codes for pbp pro?
  1. picbasic pro and mplab IDE
    By soelinnhtet in forum mel PIC BASIC Pro
    Last Post: - 1st March 2010, 09:57
  2. How to configure SPI in PICBASIC PRO?
  3. PICBasic Pro interfacing with graphic LCDs
    By Demon in forum mel PIC BASIC Pro
    Last Post: - 30th April 2005, 06:34
  4. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 18:15
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 22:19
