AD Negative Voltage reference
Results 1 to 5 of 5
    SWITZERLAND (french speaking)
    Default AD Negative Voltage reference
    Hello,
    I need to measure a 5V range but because of the voltage-regulator's "adjust" pin, the relative 0V (zéro) is already 1,2V!
    Currently, the range is from 1,2V to 6,2V if measured against Vss (GND).
    I already set ADCON0.6=1 (+Vref) and use a 6,2V Zener.
    Now, AD reads from Vss to +6,2V.
    But when I need to read "0V" (zéro), AD will still give me something like 70 (8bit res) because I can't get lower than 1,2V.
    How can I pull the GND up from 0 to 1,2V or what is the way to do it right?
    Roger
    Hi Roger,
    Are you really putting 6.2V on a PIC pin?
    Sounds dangerous to me. But maybe I'm missing something.
    Apr 2006
    New Hampshire USA
    Default Not to be negative
    Hi Roger,
    Pin input should generally not exceed Vcc on most ICs including the PIC. Your A/D input should be lowered by some means to 5V maximum (assuming you are supplying 5V to the PIC). Probably the simplest way to do this is with a voltage divider.
    See Darrel’s helpful post:
    http://www.picbasic.co.uk/forum/show...=2010#post2010
    There are ways to negate the regulator’s 1.2V. All ways would add to your circuit complexity. Depends if you want to just subtract it from the PIC A/D reading, or really make the output from the regulator go all the way down to zero volts. You may want to bump the resolution up from 8 bits to 10 bits and just work around the missing 1.2V chunk with programming.
    Anyway, don’t put more that the supply voltage into the pins (or negative voltage either ).
    -Adam-
    Default This is how it looks like
    Voilŕ, this is how my circuit looks like:
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1820&stc=1&d=118301268 7">
    Voltages I measure are:
    1.- GPIO.5 = HPWM = 1,2V to 6,2V;
    2.- GPIO.1 = AD = 1,2V to 5,1V.
    To make it work (voltage control), I must connect R5. In the same time, voltage on GPIO.5 raises up from 0V to 1,2V.
    Do I have to "protect" GPIO.5 pin against this 1,2V even if it is an Output?
    If yes, how?
    NB: is Vref limited to max 5V?
    Roger
    Apr 2006
    New Hampshire USA
    Post Absolute Maximum Ratings
    Hi Roger,
    PIC devices have a good deal of protection built into their design.
    There is the equivalent of Zener diodes on each I/O pin.
    These “voltage clamps” help to protect the device from us.
    The protection can handle a bit of “over voltage” caused, current (clamp current), but there is a limit.
    The PIC12F675 has a limit of 20 mA output clamping current.
    (Output clamp current, IOK (Vo < 0 or Vo >VDD) 20 mA).
    Your schematic diagram shows R1 protecting the 12F675 HPWM Output pin (GPIO.5).
    The protection depends upon the (over) voltage and the resistance value of R1.
    -Adam-
    Quote Originally Posted by PIC12F629/675 Data Sheet
    Absolute Maximum Ratings PIC12F675
    Voltage on VDD with respect to Vss -0.3 to +6.5V
    Voltage on MCLR with respect to Vss -0.3 to +13.5V
    Voltage on all other pins with respect to Vss -0.3V to (VDD + 0.3V)
    Input clamp current, IIK (VI < 0 or VI > VDD) ± 20 mA
    Maximum output current sunk by any I/O pin 25 mA
    Maximum output current sourced by any I/O pin 25 mA
    NOTICE: Stresses above those listed under ‘Absolute Maximum Ratings’ may cause permanent damage to the device.
    http://ww1.microchip.com/downloads/e...doc/41190c.pdf
  1. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 21:32
  2. ADC - 2 channels but not same voltage reference - how to?
    Last Post: - 25th November 2007, 20:03
  3. COMPARATOR - Voltage Reference settings
    Last Post: - 9th October 2007, 08:06
  4. Grounding Negative voltage through I/O pin
    By Squibcakes in forum Schematics
    Last Post: - 31st July 2006, 13:12
  5. Help Read negative voltage
    By gzorzi in forum mel PIC BASIC Pro
    Last Post: - 25th October 2004, 08:42
